Removing graphics
Removing graphics
Well ive got a good start on removing the graphics on the toon. I took the power washer and blew the old stickers off, now I'm stuck with the sticky residue!! I've tried everything to get it off and the only thing that works is ac coil cleaner.....do any of you guys have any tips?????? Once there all removed I'm going to sand till smooth then prime and paint! I'm wanting to get it done asap because my new double bimini and wall mount led nav lights I ordered are in!!!
2006 dodge ram quad cab
Crosby Texas
Crosby Texas
Re: Removing graphics
WD 40 works
or 3m makes a adhesive remover or your wife probaly has the goo be gone in the house
Mike Sandy Brent darcie Alex
07 Palmbeach Echelon 115 Opti Max
05 GMC Qaud Cab 1500
Thanks Tooncrazy, I've been scrubbing like crazy trying to get that stuff off!!!!!I'm extremely anxious to get the new bimini on....I'll take pics tomorrow of the process!
Crosby Texas
Crosby Texas
- shadow-13x
I would refrain from the a/c coil cleaner, as I believe most of them are muriatic acid solutions.
WD 40, 3m adhesive remover and goo be gone do the job. Gasoline might work, but is also very dangerous to use. You might try a little less dangerous charcoal lighter fluid--commonly used to clean vinyl floor mastic off flooring during installation.
One of these should work.
- The_Hellbilly
I use Googone from walmart
2005 Voyager 22ft Tritoon
2004 Honda 135hp
2004 Honda 135hp
i would not use todays gasoline it will dry out the vinyl so bad it will crack open in a years time
Try Skin-so-soft from Avon. My wife uses it to get adhesive off stuff and it works great on squeaky spots on the dock.
F225 Yamaha
F225 Yamaha
- Parasympathetic
ditto for wd40.
2015 Ranger RT175
Yamaha 70hp
Lake Wappapello, MO
- shadow-13x
he was asking what to use to remove the glue residue left behind.tooncrazy wrote:i would not use todays gasoline it will dry out the vinyl so bad it will crack open in a years time
this space for rent
Double ditto on WD-40. The real Cat's Meow!
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
Lake Conroe, Texas
2006 Yamaha F225
Triple-ditto on WD-40 to remove glue residue.
Before
After removing sticky stuff and sanding smooth
After masking off the rails
After a few coats of primer
Now some red paint to match the tow truck
Another shot
I'm really happy with the way it turned out! I love the coler red and now it matches the truck
Another shot
Crosby Texas
Crosby Texas
