Storage ideas?
Storage ideas?
Storage idea's thought this may be a good idea to see what ideas u guys have on any ideas from tackle to storage containers to anchors. At cabelas I found these bottom bouncer bags to keep them organized. For crank bates I found the 8" special mate boxes at Franksgreatoutdoors.com for 50 bucks they work great. I wish someone made a prop box an anchor box like a cordless drill plastic case to make them less damaging in sliding around under a seat. For my little companion grill by New holland after going to the stores I found a tub at k mart that fits it awesome! So if you guys have any great ideas let the rest of us know.
2008 Playcraft Extreme 2600
2008 300 Mercury Verado
2008 Bear Trailer
Iowa
2008 Bear Trailer
Iowa
Re: Storage ideas?
I like a 50 cal ammo can for a tool box. It is gasketed so the tools stay dry.
Re: Storage ideas?
the cheap pistol cases make good storage containers. Doskocil and plano are around 10 bucks for the double and if you don't need the foam just remove for more area.
something like this........think even walmart has em
http://www.gunaccessoriesusa.com/guncas ... ncases.htm
Re: Storage ideas?
we use an old milk crate to store our mushroom anchors... works well... let's the water run off but yet keeps the anchors secure and out of the way when not in use...
- Ron Burgundy
Re: Storage ideas?
A 10 gallon paint bucket is one of the most used thing on my boat. I throw in my squid and shrimp bait so when the ice melts it dosen't get all over the deck. I toss in my anchor after pulling it up to keep sand off the deck. It's also good to keep small baitfish before I cut them up so they don't take up room in the livewell.
Re: Storage ideas?
Thought this would blow up a bit more than it has. What do u guys do with your ropes anchor,ski,docking?Ron Burgundy wrote:A 10 gallon paint bucket is one of the most used thing on my boat. I throw in my squid and shrimp bait so when the ice melts it dosen't get all over the deck. I toss in my anchor after pulling it up to keep sand off the deck. It's also good to keep small baitfish before I cut them up so they don't take up room in the livewell.
2008 Bear Trailer
Iowa
2008 Bear Trailer
Iowa
Re: Storage ideas?
I hang lines on the rail so the dry quickly and are easy to grab when you need one.
Re: Storage ideas?
captainjack wrote:Thought this would blow up a bit more than it has. What do u guys do with your ropes anchor,ski,docking?Ron Burgundy wrote:A 10 gallon paint bucket is one of the most used thing on my boat. I throw in my squid and shrimp bait so when the ice melts it dosen't get all over the deck. I toss in my anchor after pulling it up to keep sand off the deck. It's also good to keep small baitfish before I cut them up so they don't take up room in the livewell.
My docking ropes stay attached to boat and over the rails and tucked between seats. My anchor I use a plastic milk crate also. Coil the rope then lay anchor on top. when you throw anchor rope flows out and when pulled in the crate keeps it loose and again the anchor holds it down.
Re: Storage ideas?
On page 38 of general toon discussion texaspontoon had some good ideas on this subject, I'd post the link but don't know how!
2006 dodge ram quad cab
Crosby Texas
Crosby Texas
Re: Storage ideas?
This is "How to post a link" click on URL button above, you will then see this open in the posing section then copy your link. Place your curser in the middle between ]l[ like this and paste your link and you should be good to go. You can check your link by previewing post if you care to to see if you've got it "right".Mrtoler wrote:On page 38 of general toon discussion texaspontoon had some good ideas on this subject, I'd post the link but don't know how!
By the way is this the post you were referring to viewtopic.php?f=2&t=6438.
Re: Storage ideas?
If you like white buckets, check out the ones chlorine tabs come in (swimming pool).
They use a screw on lid. That is better than the snap on lid. There is a tall one, about the size of a drywall mud bucket and a shorter one that probably fits under most seats.
Re: Storage ideas?
Saw an interesting idea today on a Benny.
The guy had a piece of 4" PVC mounted vertical on the corner of the rail (outside the fence) and he drops the stem of his anchors in them. One front and one back.
There was a milk box on the deck with the rode in it.
- kryptonite
Re: Storage ideas?
For the ropes...
I use those cheap electric cord plastic wrap deals. Works good for all the ski ropes ect....
The reeled one is for the anchor rope....
- rsz_ropes.jpg (57.72 KiB) Viewed 16249 times
- Leisure Kraft
Re: Storage ideas?
Overton's appears to have an organizer, probably for under-seat storage.
http://www.overtons.com/modperl/product ... rchID=4006
I personally have some of those nifty mesh bags from the camping world that also work well.
http://www.backcountryedge.com/equinox- ... -x-16.aspx
Michael Blankenship 931-484-2681
Leisure Kraft Pontunes - 1996 Peavine Road, Crossville, TN 38571
http://www.LeisureKraft.com
Find us on the Pontoon Forum members map: http://www.zeemaps.com/295621/Leisure_Kraft_Pontunes
Re: Storage ideas?
those bags look like a good deal but they're discontinuedLeisure Kraft wrote:Overton's appears to have an organizer, probably for under-seat storage.
2008 Bear Trailer
Iowa
2008 Bear Trailer
Iowa
