suntracker fishin seats wont come out of floor
kenbob62
#1 Post by kenbob62 » Wed Oct 23, 2013 1:16 pm
tried everything to remove the posts for the front 2 fishin chairs,theyre seized in the mounts on the floor,tried pipe wrench air hammer,floor jack,rust penetrant,anyone else had this prob? and if so did anyone get any help from tracker?thinking of contacting them since I had the same issue years ago with a sea nymph and they replaced all seat post for free. and yes I do use the boat in salt water. 2008 suntracker fishin barge
kenny...2005 32 ft party cruiser ,2005 silverado 6.0 4x4 what a long strange trip its been
Re: suntracker fishin seats wont come out of floor
#2 Post by lakerunner » Thu Oct 24, 2013 4:54 pm
Are they the pin type? I had problems on another toon and went under and used a small bolt and hammer to drive it up.
BillieS
#3 Post by BillieS » Thu Oct 24, 2013 6:01 pm
Had the same problem. I used a sledge hammer and drive pin underneath with someoneusing a pipe wrench on top and PB blaster spray. Finally got them out and lubed them on a regular basis after i sanded down the rust off them and the hole they set in.
2008 SunTracker Fishing Barge signature series 21/60HP Bigfoot 4 Stroke EFI, 85# Thrust Minn Kota Terrova Trolling motor W/Remote control and foot pedal
lemans81
#4 Post by lemans81 » Sun Oct 27, 2013 4:05 am
On our previous toon we had this issue, we were able to drive something through from the botton on one of them. The other we ended up taking a torch to the metal and beat it out, we damaged it beyond use unfortunately. Both posts had been in place without removal for about 7 years.
24' Sweetwater w/tritoon, 4in strakes, 70% underskinned, 150HP HPDI Yamaha 2stroke.
“It is better to keep your mouth shut and appear stupid than to open it and remove all doubt.”
-Mark Twain
Ron Burgundy
#5 Post by Ron Burgundy » Sun Oct 27, 2013 8:56 am
Same problem here. A good wack from underneath should get er dun.
oldmn19
#6 Post by oldmn19 » Sun Oct 27, 2013 11:01 am
I had results on a Bass Boat by heating the post near the base good and hot took about 30 mins, then let it cool completely and rocked it using lots of Blaster around it at base. Finally came free. Sanded socket and post lubed well and no problem. you should remove and install them a few times a season. :donno
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
lclevel1
#7 Post by lclevel1 » Sun Oct 27, 2013 4:02 pm
There's a penetrant that's used in refineries to loosen up rusted bolts that may be 30 years old or older. It works VERY VERY well.
Its called Kroil. You spray it on and let it soak for about 30 minutes. When you come back, in most cases it takes very little effort to remove the nut from the stud bolt.
It's the penetrant of choice in most plants.
[color=#0000FF]2013 Suntracker Fishing Barge 24
115 Mercury[/color]
Ray Jr.
#8 Post by Ray Jr. » Sun Oct 27, 2013 4:30 pm
An old trick I have used in the past to free up severely rusted things is pour some Coke on it and let it sit over night
2010 150 HP Mercury Optimax
Capt Sully
#9 Post by Capt Sully » Sun Oct 27, 2013 4:46 pm
Coke works good on battery posts also :thumbsup
2012 Xcurison X23C
Yamaha 90 hp 4 stroke
Maritime mobile KD4LZL
Lake Allatoona, NW Ga.
FVC USCG Auxiliary
Vietnam 66 / 67
RonKMiller
#10 Post by RonKMiller » Sun Oct 27, 2013 8:14 pm
ATF works every bit as good as Kroil or PB blaster... just let it soak for 24 hours and apply low heat from an electric heat gun.
BoatCop
#11 Post by BoatCop » Mon Oct 28, 2013 4:36 pm
I've found that a mixture of ATF and acetone (50/50) works better than anything on the planet.
This coming from a 28 year USCG marine mechanic.
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
