How big is the fuel tank on your boat?
Bugsbunnyboater
The tank that came with my used sweetwater pontoon boat is six gallons and the outboard is a tohatsu 25hp.
I wonder if I need to take an extra tank if I want to run the river all day. Six gallons does not seem like a lot.
I have the boat in a wet slip at the beaumont yacht club and they sell gas there.
Re: How big is the fuel tank on your boat?
My tank is 24 gallons. On my old pontoon I had two six gallon external tanks. I always made sure that one was full and the other not close to empty. It is better to have more fuel than you need than a little less.
If you are premixing your six gallon tank I would definitely get another one just to keep the mixing easy in addition to having a spare full tank.
My new boat has 21 gallons. I like it that way because I don't want to "invest" in a tank of 100% gasoline in the Fall--for it only to sit.
My old boat had a 6 gallon metal OEM tank and a 12 gallon plastic Moeller tank.
Since the farthest I can go away on my lake is 15 miles, my capacity is sufficient.
Used to have two portable six gallon tanks on the back of my logs. One day one tank went dry as a barge was coming down the river at me. Fastest tank change ever! Later that day I ordered a 13 gallon tank to mount on the deck with a real gas gauge.
I have two tanks on my boat: one is stock 32 gal the other is after-market 19 gal for a total of 51 gallons. I have a Yamaha F150 on the back.
2012 Bennington 24 SSL
150 HP Yamaha
.45 1911 Security System
150 HP Yamaha
I have a 45 gallon tank. I never worry about having a full tank left over in fall with my 300 VRod on back. I can burn through that in an hour and a half.
Ive already burned more gas this year than two seasons with my 115.
pond tuuunes
I have a main 70 gal, and a reserve 30.JT
And Ill bet you can burn a lot more than me !
pond tuuunes
Not this year
Uh oh, boat is down ?
pond tuuunes
Center toon getting welded now, then put engine back in.
6 Gal. No marina. Not much point in me having larger than 6 Gal since that's the legal limit for filling a portable tank.
Mark
Rush Lake, Atlanta, MI
35 gallons. Have never burned more than 9 in a day of cruising and tubing.
However big (or small) your tank is, always remember the rule of 1/3s.
1/3 to go out
1/3 to get back
1/3 reserve for contingency.
1/3 to go out
1/3 to get back
Alan
2016 Chevy Tahoe
2009 GMC Sierra
2001 Jeep TJ Wrangler
1999 Southwind 34L MH
2 little Basset Hounds
2016 Chevy Tahoe
2009 GMC Sierra
Bugsbunnyboater
I will look for an extra tank. I guess it's best to more gas than I need than be stuck on the river.
guy48065 wrote:6 Gal. No marina. Not much point in me having larger than 6 Gal since that's the legal limit for filling a portable tank.
WOW, never heard of that law. I know TSC down the road sells 14 gallon tanks. Maybe a STATE law?
http://www.tractorsupply.com/en/store/s ... _vc=-10005
Sheridan, Indiana
Sheridan, Indiana
