So pulled the toon home from the lake for the winter and decided to go ahead and replace carpet and furniture. Here's the situation.
1997 voyager 20ft fish & cruise
onboard 22 gallon gas tank
Upon removing the wrap around i noticed the onboard gas tank extends under the corner section. The plastic base is cut out and molded perfect for the tank. I wanted to replace the furniture with a new set from pontoon stuff but don't believe they carry any corner sections comparable. Relocating the tank is not possible.
Any ideas or suggestions?
voyager project
Re: voyager project
Pictures would help.... Replace the fuel tank? Different furniture? Jig Saw?
Re: voyager project
Welcome Fokker!
That set up may be hard to change. I am wondering if a different tank on the stern might work. or two smaller tanks
James Myers
Re: voyager project
Hello
What type of corner do you have? Is it the larger 36" radius, I know we only show a 30" radius or our standard corner but we have a new larger 36" radius corner in the works that will be done next month. Can you post a picture of what you have and I can let you know if it will work or shoot me an email and I'll see if we can help.
Thank you for the opportunity!
My personal email is jmyers1165@gmail.com
Re: voyager project
will try to get some pics up after work.
thanks
thanks
Re: voyager project
If you find out, let me know. I got the same layout and have thought about how I would ever replace it down the road...
Re: voyager project
Fire a post off to PS and see if they have an answer
