Welcome, Looks good, I was looking at them, so this is an add on you can get for it I'm guessing, you think they would sell one that came that way, and didn't they have one you could set to keep you a certain distance from shore while trolling ?
http://mk.factoryoutletstore.com/detail ... 66310.html
Technical Features for Minn Kota i-Pilot System
f/ PowerDrive V2
The Minn Kota 1866310 is a i-Pilot wireless trolling system accessory for PowerDrive V2 that automatically controls and steers the boat using the GPS technology. It can be locked onto a fishing spot and it works like an electronic anchor. The i-Pilot records a successful path and retraces it automatically with its playback feature and sets a cruise control for the bait presentation.
The LCD screen and function icons are 20% larger and the keypad has improved visibility, durability, and tactile feel. The remote comes with a slimmer, more ergonomic design as well as an easy-access battery compartment.
1866310 Features:
Product # 1866310
i-Pilot f/ PowerDrive V2
20% Larger Screen
Backlight LCD Screen
Record A Track
- Stores the Track & Retraces Later
Spot-Lock
- Stores Up to 6 Spots
- Corrects f/ Wind / Current / Drifts
- Allows You To Return To Your Spot Later
CoPilot & Cruise Control
- Control Speed & Steering
- Control Prop On / Off
- Gives You Unparalleled Bait Presentation
Advanced AutoPilot w/ GPS Accuracy
- Point Trolling Motor In Direction You Want
Note: once an i-Pilot is installed on a PowerDrive V2 motor, the foot pedal is no longer compatible
