Boat in the Yard needs Moving
Just had a river rise here and was trying to keep my pontoon from floating away. In doing this I pulled it up into the yard, the river went down so fast it is now sitting in my yard 100' from the water. My question is what is the best way to lift the pontoon and return to the water? Hook onto the eyes on the 4 corners? Maybe forklift under the deck? Drag it up near the water and hope to get pulled in or pushed in some how? I'm open to suggestions from anybody who has attempted this. Boat is a 20'er w/60hp engine. Thanks ahead of time.
Re: Boat in the Yard needs Moving
If you have a forklift big enough to lift it and with long enough forks, that would work. Here's a photo of mine is being launched from dry dock. I wouldn't risk trying to drag it by the eyes. Is there any way to jack it up high enough to slide the trailer under it?
- image.jpeg (101.47 KiB) Viewed 9151 times
Borrow, beg, or possibly rent a crank up trailer is likely your best bet.
get enough round logs.... lift it, put round logs beneath... roll towards water.... repeat....
maybe.
maybe.
Several pieces( 5 or 6) of 4 " pvc sewer line about ten feet in length will work. You place them under neath the logs and roll it back to the water. 2 or 3 good men can do this. If its down hill, the big problem will be not letting it get away from you.
I have done this and if you have the pipe its real easy, these toons are relatively very light and the pvc will not harm the logs.
A trailer is fine but you have to have something to pull it through your grounds. Hope this helps.
As was said, round wooden logs will work but are more expensive if you have to buy them. And they are heavier.
Thanks to everyone for your suggestions. Forking it will not work nor will rolling due to the terrain. I contacted Godfrey and they said it would be OK to pick up the boat on all 4 corners and place it back into the water or on the trailer. I'm going to get a fork lift and pick it up with a piece of drill pipe and those big yellow tow slings. If I get a chance to take a picture I'll post. Wish me luck.
1. Get an oxy-acetylene torch.
2. Light it, and adjust the oxygen/acetylene mix for the hottest flame you can.
3. Snuff out the flame. (I have found that a 2X4 works OK).
4. Fill 4 33 gallon garbage bags with this perfect mix of oxygen and acetylene.
5. Put the bags under your boat.
6. Figure out a way to simultaneously ignite all 4 bags (I'm not going to give you ALL the answers!).
7. Watch your pontoon reach low earth orbit in less than 10 seconds.
8. Replace all the shattered windows in your neighborhood.
Warning: A sandwich sized baggy of oxy-acetylene will blow a metal garbage can lid over 40 feet in the air. Be careful!
Do not ask how I know this.
Oh, and WELCOME!
Oh, and WELCOME!
Bob bob bob , you can't be helping people blow their self's up, ISIS has complained about your post and said if anyone going to blow a boat up , they have to convert to muslim first
Waterlogged
jmas4u please don't listen to BobG, but if you do, please video it so we can all enjoy the show. Bye the way, welcome aboard this gathering of miss fits.
Glenn
Glenn
2008 Mercury 115 4 stroke
And don't take every thing people say here as the truth, as some times they like to pull your leg for the fun of it, and might lie a little, when it comes to Bob our favorite lib, don't believe any of it
Bob,BobG wrote:1. Get an oxy-acetylene torch.
Oh, and WELCOME!
We used to put just a puff of oxy-acetylene in a 2 liter drink bottle, then Screwed the cap back on. Put it in a paper bag, lit the bag and ran like hell. Kaboom!
DON'T TRY THIS! HIGHLY DANGEROUS, EXTREMELY LOUD AND WILL PROBABLY GET YOU ARRESTED!TDJ2591 wrote:Bob,BobG wrote:1. Get an oxy-acetylene torch.
Oh, and WELCOME!
We used to loft a single 33 gallon trash bag under 3 33 gallon trash bags filled with helium. Tape a black cat to the side of the boom bag,and make a time delay fuse. Light and release. Beautiful air burst!TDJ2591 wrote:Bob,
Time delay fuse:
Soak newspaper strips in a solution of Sodium Nitrate and water (or did we use Potassium Chlorate?). Let it dry completely. Burns about an inch per minute.
Nope. Not even when strong winds caused the boom bag to drift right over the Northglenn (CO) Cop Shop. Of course we were Sh!tt!ng Bricks at the time.TDJ2591 wrote:DON'T TRY THIS! HIGHLY DANGEROUS, EXTREMELY LOUD AND WILL PROBABLY GET YOU ARRESTED!
We make big bangs all the time, come camping with me this weekend, now we might not be doing this there, but they were be plenty of bang at our pyrotechnic camp out, here's how we dig holes, that is the Title, Digging a hole the pyro way, that was a real big m-80, a five gallon bucket size one
