Switch problem
My toon has switches like all the other ones out there. I have a master switch problem is sometime it will work and sometimes it will not. I have tried checking the wire at the switch and it seems to have a good connection. Any suggestions on what and how I can check the problem further without taking the toon into a service shop?
Thanks for any help
Master switch problem
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
2013 115 Yamaha
Re: Master switch problem
If you have a multi-meter, disconnect the wires to the switch and test for continuity. This will at least verify the internals of the switch are okay. It sounds like you may have a bad master switch.
