Marine Electrical Tape?
urbnsr
#1 Post by urbnsr » Sun Jun 26, 2016 4:19 pm
I have used electrical tape under our console only to find that the tape adhesive turns to goo maybe because of the heat build-up under the mooring cover most of the time.
Is there a product better suited than plain electrical tape? Maybe just switch to heat shrink tubing after applying a bit of dielectric grease?
Thanks!
Paul
teecro
Re: Marine Electrical Tape?
#2 Post by teecro » Sun Jun 26, 2016 7:36 pm
I will only use Scotch brand Super 33+ Electrical tape here at work on board ship as well as at home, car, bikes, boats etc...
It is the absolute best tape on the market hands down end of story....
Heat shrink tubing is very nice but awkward to use in a lot of situations...
urbnsr
#3 Post by urbnsr » Mon Jun 27, 2016 2:45 am
Great - Thanks. I will check local availability and go from there.
Paul
teecro
#4 Post by teecro » Mon Jun 27, 2016 3:36 am
urbnsr wrote:Great - Thanks. I will check local availability and go from there.
Should be available at your local ACE, True Value, Lowes, HD etc...
urbnsr
#5 Post by urbnsr » Mon Jun 27, 2016 5:30 am
Yes, you're right. I looked at Ace.com, but only found a 10 pack. Went to the local Ace and they have it by the roll. Thanks...
Paul
gerg
#6 Post by gerg » Mon Jun 27, 2016 6:07 am
I use Scotch 70 Self-Fusing Silicone Rubber Electrical Tape.
It's expen$ive stuff, but I got lucky and found 8 rolls in the bottom of a box of stuff I bought at an industrial auction for a couple dollars. Otherwise I would have never heard of it!
gerg
2003 SunTracker Party Barge 200 'RiffRaft'
2017 Mercury 60hp Command Thrust
Brookville Lake, Indiana
- Why do they call it Common Sense when so few people seem to have it? -
urbnsr
#7 Post by urbnsr » Mon Jun 27, 2016 6:45 am
Good to know gerg. Thanks...
Paul
