Bennington ski pylon diameter?
Kevin1741
#1 Post by Kevin1741 » Thu Feb 02, 2017 6:02 pm
Hi all, im looking to make a flag pole for the boat i have on order and need the diameter of the ski pylon. I would assume the late model boats have the same size. Thanks
mrlouis
Re: Bennington ski pylon diameter?
#2 Post by mrlouis » Thu Feb 02, 2017 6:30 pm
Question, you are ordering a brand new boat and you want to make a flag pole ? why don't you just order it with the ski pylon that you can
attach the flag pole , 3-4 zip ties and it won't move then when needed you have a attachment to pull ski's and tubes ?
Don
Kevin1741
#3 Post by Kevin1741 » Thu Feb 02, 2017 6:35 pm
I ordered a ski pylon with the pontoon and going to make mounts that attatch to the pylon and still allow the pylon to be used while flying my flag!
mrlouis
#4 Post by mrlouis » Thu Feb 02, 2017 6:44 pm
that should work just fine you can always change the pole length if necessary to allow it to be higher when pulling tubes etc.
good luck
