Need help
Need help
Sorry tried to edit my post but couldn’t. Problem is I have switches for the running lights anchor lights bait tank. Also have a master switch that needs to be turned on prior to others being used. The master switch is not working. Check fuse okay. Any suggestions?
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
2013 115 Yamaha
Re: Need help
Do you have a multi meter?
Simple wiring is battery to master switch to fuse block.
So can you check main switch? 12v or continuity, and make sure work
.ugh..switch it on and off continuity should go blank on meter to zero when moved this will check switch.
Also with multimeter on 12v dc, with switch off 12v one side nothing, otherside, flip switch 12v both sides
Also check ground from batety to ground block, okay?
I have had a few adult beverages....so just looking for answers
- NonHyphenAmerican
Re: Need help
Disconnect the battery, clean terminals, re-connect.
Re: Need help
Update tho is what I like about this group. Asked a question have a problem someone on here knows the answer. Thanks to all I did what was suggested and the problem has been fixed. Cleans the cables on batteries problem solved. Thanks again guys saved me money and weeks of down time on the toon. Thanks again
2013 115 Yamaha
2013 115 Yamaha
Re: Need help
