Where to find Aluminum Edge Trim Molding for around the outside edge?
palepimp
#1 Post by palepimp » Thu Oct 21, 2021 1:45 pm
I'm rebuilding a 24' '96 Starcraft DLX. It had old standard aluminum colored molding around the edge. I was hoping to radius the 4 corners, and replace with some powder coated or black anodized aluminum corner caps, and get the same color aluminum trim around the outside of the boat.
I found some aluminum companies online, looks like I can get black anodized aluminum trim in 1 1/2" x 1 1/2" x 1/8" like here:
https://wgsonline.com/1-1-2-x-1-1-2-x-1 ... XoQAvD_BwE
Would this work? It looks like existing aluminum trim has a bunch of ridges and is a lot larger in general. Anyone have any experience with this?
1995 Starcraft 240DLX
Re: Where to find Aluminum Edge Trim Molding for around the outside edge?
#2 Post by curtiscapk » Fri Oct 22, 2021 6:57 am
#3 Post by bansil » Fri Nov 05, 2021 4:27 pm
Eta...same thing I said OP....good luck 8n search :thumbsup
:donno radiused around corners is $$$ each would be custom.
Search for 90 alum corner boat trim and cover straight pcs with it.
I can't give much help other than a Google search and bump.
We have an older boat(actually an antique) 92 model :smoke , I don't care about the haters over perfection :donno 99% are visiting our lake....
Kytoon
#4 Post by Kytoon » Tue Jul 05, 2022 4:29 pm
Bills has the pontoon edge as well. Don't know how I missed his website when doing the build he has a bit of everything.
#5 Post by curtiscapk » Wed Jul 06, 2022 7:04 am
Yep I've always wanted to make the trip to walk his lot, just haven't found the 2 days it'll take!
