Tach fix
Tach fix
#1 Post by lakerunner » Sat Oct 10, 2009 5:43 pm
Ok guys and gals I need your help
Year or so ago we took a lightning hit at home. The boat got some of it also though not direct. My tach stopped after that along with nav lights. I changed blown fuses and got nav lights back but didn't mess with tach. Well my girls gave me a $100.00 Bass Pro gift card so I decided to replace tach. I installed it and all wires are right yet it doesn't work. Do any of you know if there is a fuse under cowel for that as I can't find one. My charging system is working fine so not sure why tach doesn't.
Re: Tach fix
#2 Post by HandymanHerb » Sat Oct 10, 2009 6:33 pm
May have fried a wire or connection, shouldn't be a fuse in a tach line, if you have a meter ohm it out, you can start by putting 2 ends together and get to see what the other end tells you, if it's open you got a bad wire, if it shows closed loop separate the other ends and see if it goes open.
But I would bet one of the wires being burnt in two
Jerry D
Re: Tach fix
#3 Post by Jerry D » Sun Oct 11, 2009 4:36 am
My Yamaha has fuses under the motor cover for all the engine peripherals, not sure about a Merc.
Jerry...
