Fuel Injector Cleaner
WaltF
#1 Post by WaltF » Mon Mar 22, 2010 10:59 am
Hey All!
So, what kind of fuel injector cleaner would you all recommend?
Im asking so i can run some through my Saturn v6 (its a Honda engine), but i imagine it would also be good for boat engines too. :nana
Colorado Springs, CO.
captain kurt
Re: Fuel Injector Cleaner
#2 Post by captain kurt » Mon Mar 22, 2010 11:14 am
Hey Walt the best product I've found is Lucas. I use it in my bronco's, the Class C R.V all my autos yes and the pontoon. You can find it almost any where Wal-Mart, Napa auto supply ect. 1 gallon is about $ 31.00 or smaller bottles 8 oz about $ 4.00 great stuff. :nana :2cents
2001 Premier
250 R.E Majestic
4.3lt Tri toon
Lake Tahoe, Nv
2001 Dodge 1500 5.9lt
Hey! What's in your Bucket?
slingshot
#3 Post by slingshot » Mon Mar 22, 2010 11:55 am
I'm an AMSOIL man myself. Great fuel system cleaner in general.
2007, 2570 Crest LE II
Yamaha F150
#4 Post by dockholiday » Mon Mar 22, 2010 12:05 pm
I have used gumout products for years, before using the seafoam. The gumout is a little cheaper than the seafoam, although don't know if it deals with the water issue. I mainly use the mpg on the computer to show when I need to put it in. Those are my two main ones I use.
Had a guy that worked on my suv said he couldn't believe how clean the engine was for its age. So, I guess it work pretty well for the money. On the suv it only seem to vary about 2mpg though.
GXPWeasel
#5 Post by GXPWeasel » Mon Mar 22, 2010 1:08 pm
I've used Lucas and Gummout before on my Silverado and GP. I dump a can of it in the Silverado on EVERY oil change, and the Throttle body is still clean as a wistle with 194,000 miles. :devillol
WaltF
#6 Post by WaltF » Tue Mar 23, 2010 9:18 am
Thanks!
I poured a bottle of Lucas into the car and off i went!
Hopefully the engine will notice that i love it and run for a zillion miles with major work!
Yaa... riiiight.. heh :rofl
oldmn19
#7 Post by oldmn19 » Tue Mar 23, 2010 10:25 am
All the above are good, I use Techron in my stuff, most Auto Parts stores carry it. About every oil change is good!
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
#8 Post by lakerunner » Tue Mar 23, 2010 2:49 pm
Sea Foam
Parasympathetic
#9 Post by Parasympathetic » Tue Mar 23, 2010 9:03 pm
A lot of the auto techs like Techron and/or Seafoam. I use one or the other just before oil change.
2015 Ranger RT175
Yamaha 70hp
Lake Wappapello, MO
layne4
#10 Post by layne4 » Thu Mar 25, 2010 5:10 pm
Seafoam
2007 Playcraft Powertoon 2400
I'd rather be lost at the lake than found at home.
#11 Post by badmoonrising » Fri Mar 26, 2010 5:42 am
Sea foam...use it in all my vehicles but switched to Startron Blue for winter storage in the boats.
layne4
#12 Post by layne4 » Fri Mar 26, 2010 7:00 pm
out of curiousity what made you switch?
#13 Post by badmoonrising » Fri Mar 26, 2010 7:34 pm
Last spring I had problems. My boat would start fine, idle fine then die when I gave it gas. Next trip, wouldn't idle but ran ok at mid-open throttle...took the carb apart and there was yellow debris inside (see my "Well there's your problem" thread). The fuel line had a plastic liner (suspiciously the same color as the debris in the carb) which had deteriorated (dunno if due to ethanol, the Seafoam or the combo) but I used Seafoam since the boat was new without problems. I checked in at the marina office to report what happened and they said they had about 100 out of 400 boats with similar issues, even a Coast Guard patrol boat (didn't matter whether people used street gas or marina gas).
The owner said he recommended Startron, winter and summer. Nothing else. Last fall, I put Startron in the last tank of the year and ran it dry...well see what happens this year. I'm de-winterizing the boats next week.
I filed an insurance claim with Boat US and the adjuster said it was a widespread problem last spring. My claim was paid (carb, fuel line, fuel pump was replaced).
Not blaming the Seafoam, I suspect the fuel hose wasn't ethanol safe (not Mercruiser's fault, whoever installed the motor apparently used the wrong fuel hose). The replacement hose had no liner of any kind.
#14 Post by badmoonrising » Fri Mar 26, 2010 7:44 pm
Here's the thread I mentioned above:
viewtopic.php?f=2&t=2284&hilit=problem+fuel+line
Parasympathetic
#15 Post by Parasympathetic » Fri Mar 26, 2010 10:15 pm
And apparently Seafoam is an alcohol based additive, which many of us didn't know until just recently. So, although it's a great injector/throttle body/fuel/valve cleaner, it's probably not the best thing to winterize your 10% alcohol fuel. So, I switched this year for my other toys to Startron, but I was too late to do my boat. I'll find out in a couple of weeks if it's OK.
2015 Ranger RT175
Yamaha 70hp
Lake Wappapello, MO
