Size of hand winch
justfloating
Size of hand winch
#1 Post by justfloating » Sat Jun 05, 2010 9:43 pm
I am just doing the final touches on my DIY pontoon trailer and was looking for some advice on which would be the best for me.
The pontoon is a 19' that at the moment I do not know what it weighs exactly but I am comfortable with the number 2000 lbs.
The winch tower I have made will accept any type or size of winch whether it be a hand or electric, do I consider one with a brake?
What are you using?
Pontoon trailer 004.JPG (34.4 KiB) Viewed 5146 times
Pontoon trailer 005.JPG (75.61 KiB) Viewed 5145 times
Re: Size of hand winch
#2 Post by lakerunner » Sun Jun 06, 2010 6:08 am
Unless you plan to winch it on the trailer a standard Wally World single gear will do just fine. Otherwise there are gear reduction winches that will drag it onto trailer from ground
justfloating
#3 Post by justfloating » Sun Jun 06, 2010 6:29 am
When I am done with this trailer I am expecting that all I have to do is point the boat in the direction of the trailer and it would just load itself.
But for those times it doesn't I want a winch that will work more than me.
tuned
#4 Post by tuned » Sun Jun 06, 2010 5:27 pm
Looks like some nice handywork.
I just got rid of my winky single speed winch and went with a 2 speed hand cranker by Dutton Lainson. I am really impressed with mine. Those guys have TONS of choices on US made winches.
Once I made my decision (2500# 2-speed with strap), I shopped around and was surprised to see that Cabelas was my best price. About $100 to my door.
Here's the linky: http://www.cabelas.com/cabelas/en/templ ... 23&Go.x=22
justfloating
#5 Post by justfloating » Thu Jun 10, 2010 9:07 am
Here's a quick update
I remembered what I said the first time I painted a trailer yellow, it takes at least 3 coats for it to cover properly and yes it is a bit bright. On the bright side :lol3 I am doubtful that trailer will be stolen.
Starburst Yellow
I am going with a 2000lbs winch.
Pontoon trailer 002.JPG (67.88 KiB) Viewed 4915 times
Pontoon trailer 001.JPG (69.51 KiB) Viewed 4913 times
Stephen
#6 Post by Stephen » Thu Jun 10, 2010 9:22 am
That is a bright yellow, but it looks good!
Stephen & Gina
"It's Aboat Time"
2007 Godfrey Sweetwater Tuscany Series, 21'
2002 GMC Sierra 1500
Lake Arrowhead, TX
"Work is hard. Distractions are plentiful. And time is short."
-Adam Hochschild
GXPWeasel
#7 Post by GXPWeasel » Thu Jun 10, 2010 9:46 am
So is your Toon yellow too? If so, that will look pretty cool, and you will definitely be easy to spot in the lot at the ramp. :nana
justfloating
#8 Post by justfloating » Thu Jun 10, 2010 10:12 am
GXPWeasel wrote:So is your Toon yellow too? If so, that will look pretty cool, and you will definitely be easy to spot in the lot at the ramp. :nana
Yes they are but not as bright, I am hoping after a couple of coats it will be a bit darker. Those picture were of the first coat on a grey primer which I think will make it look brighter.
Time will tell.
Snider4
#9 Post by Snider4 » Thu Jun 10, 2010 8:47 pm
Wow nice work! Do you hire out!?
Just curious, how much will you have in materials once your finished?
Snider4
Misty Harbor 2080RE
Merc 50
Sprinter Select 26BH
Ohio
justfloating
#10 Post by justfloating » Fri Jun 11, 2010 5:50 am
Snider4 wrote:Wow nice work! Do you hire out!?
Just pennies short of a thousand but thats everything right down to the UHMW bunk strips with the only exception of a spare tire.
I thought I wait to get one until the boat is ready as it is a kit pontoon boat which is the next project.
Woody
#11 Post by Woody » Fri Jun 11, 2010 6:07 am
Lookin' good !!
2019 Veranda 22 RFL 250SHO
