Pressure Testing Pontoons
Drago
#1 Post by Drago » Tue Jun 28, 2011 3:57 pm
Many time I've seen posts about checking for leaks and pix showing what over pressurizing can do to a pontoon. I was cleaning out the garage and ran into a new Smith acetylene regulator and realized that by piping it into the outlet of my air compressor, I can double regulate.
The outlet of the acetylene regulator is redlined at 15psi with a nice wide scale at the low end. My normal out pressure on my day to day work is around 4psi.
Hope this give anyone ideas on what sort of gauge to use.
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
Dan L
Re: Pressure Testing Pontoons
#2 Post by Dan L » Wed Jun 29, 2011 3:29 am
When I tested mine, I used/made a water manometer, much more accurate than a meter, and cheep too, it was just a plastic fitting and length of clear tube. But do it on a day when the temp is constant and with the tubes out of the sun, or you'll go nuts watching the water rise and fall with the temp/pressure change in the tubes.
Dan
GXPWeasel
#3 Post by GXPWeasel » Wed Jun 29, 2011 8:50 am
Dan L wrote:When I tested mine, I used/made a water manometer, much more accurate than a meter, and cheep too, it was just a plastic fitting and length of clear tube. But do it on a day when the temp is constant and with the tubes out of the sun, or you'll go nuts watching the water rise and fall with the temp/pressure change in the tubes.
Dan
What, no pictures of your little device?
GregF
#4 Post by GregF » Wed Jun 29, 2011 3:54 pm
The "blow" side of a vacuum cleaner is enough pressure to soap bubble test the toons with no danger of popping one.
