What speed are you getting at WOT and the size of you boat
bassn386
Re: What speed are you getting at WOT and the size of you boat
#16 Post by bassn386 » Mon Aug 18, 2014 12:55 pm
11 Bennington 2575 RlCW, 225 Yamaha, 40 mph @ 5600 rpm (wot) approx 30 gallons of fuel on board and just me.
F225 Yamaha
BobL
#17 Post by BobL » Mon Aug 18, 2014 1:03 pm
See signature for boat details.
38 mph (Iphone GPS App)
5800 rpm
2 adults
26 gallons of gas
smooth water
essentially calm wind
50' above sea level
no gear (other than the 12 life jackets I keep on boat)
Coldbrew
#18 Post by Coldbrew » Mon Aug 18, 2014 2:28 pm
2014 Premier Gemini 201 w/Mercury 90 2 stroke- Full tank w/2 adults and lots of gear - 25mph
Tow Vehicle: 2019 F-150
Home Port: Newfound Lake, NH
smoker62
#19 Post by smoker62 » Mon Aug 18, 2014 6:12 pm
2014 Crest Classic 250 with Mercury 300 HP Verado Pro, 46 mph with 45 gallons of fuel and just me on board. More to be had I think.
PlaynDoc
#20 Post by PlaynDoc » Mon Aug 18, 2014 6:59 pm
2011 Smoker Craft, Sunchaser, 22ft; merc 115; 31 mph gps
chopper6358
#21 Post by chopper6358 » Mon Aug 18, 2014 7:20 pm
1993 24ft sun tracker party barge, both biminis up, 2 people 40 gallons of gas 2003 Johnson 90hp......21 mph
1998 Crest 25' Tritoon,115 Johnson 2 stroke. 13x11 4 blade spitfire prop, pulled with 2007 GMC sierra classic 2500hd 4x4. ky lake :nutkick :thumbsup :eviltaunt
mobldj
#22 Post by mobldj » Mon Aug 18, 2014 7:33 pm
2014 excursion tri tube,150 merc,full tank of gas and 4 bodys,trim up alittle.35 max,13 folks onboard max of 22
2014 Excursion x23c
150 merc
Bugsbunnyboater
#23 Post by Bugsbunnyboater » Mon Aug 18, 2014 9:59 pm
I was shocked to see that a 25hp is getting 18 mph. My tohatsu 25hp gets 10 at wot
#24 Post by ROLAND » Tue Aug 19, 2014 2:35 am
2010 Bennington 20 footer with a Yamaha 75 4 stroke... two people on board, 3/4 or more tank of fuel and best we get is 24 mph on a smooth lake.
sunnyside
#25 Post by sunnyside » Tue Aug 19, 2014 5:40 am
See signature for boat. 54 gal fuel, 2 adults, gear, 17" SS Rebel prop
46.5 mph GPS at 5900 rpm
KPC
#26 Post by KPC » Tue Aug 19, 2014 5:54 am
Bugsbunnyboater wrote:I was shocked to see that a 25hp is getting 18 mph. My tohatsu 25hp gets 10 at wot
Remember Bugs, my boat doesn't have much on it in terms of weight. Not only that, but even though it's considered a 20 footer (log length), the deck is only 16'. If you add the weight of all my seats together, (2 sling back benches in front, two sling back chairs, a resin box bench in the rear and a resin box bench for the captain), I don't think you have 150 lbs TOTAL.
I'm finding it's all about weight with these things. When you start adding people and coolers to mine, the speed drops quickly.
That's why it's really tough to compare speeds between dissimilar boats and loads. Unless all things are equal, it can be really deceiving...not to mention frustrating.
KPC
rhorne
#27 Post by rhorne » Tue Aug 19, 2014 5:07 pm
53.3 mph at 6000 rpm's, full tank of gas and me by my self. Of course this was back in May before it got to 95 degrees and 80% humidity.
[b]If you can read this thank a teacher.
If you are reading it in English thank a Veteran.[/b]
2014 Tahoe LT Cruise 2300
2014 Evinrude Etec 250 HO
2008 Stratos 294 XL
2012 Evinrude Etec 225 HO
dodger
#28 Post by dodger » Tue Aug 19, 2014 6:49 pm
After finally getting 75 hours on the motor, flat water, no wind, 2 people, 1/2 tank of gas, 2 anchors, lots of life vests, and two tubes stowed below in center tube, we hit 6000rmp, and 40 mph.
The rest is in the sig line below. We are very happy with the new toon.
Yamaha 150
SeaStar steering
Silver Eagle
#29 Post by Silver Eagle » Tue Aug 19, 2014 8:19 pm
2007 24ft StarCraft Limited Edition. 90 hp Mercury 2 stroke I usually run 3600 RPM's at 16 mph. Mostly 2 people with top open On the Chesapecke Bay, never smooth water .If I kick it out of the hole at 5,000 rpm's 22 mph. So Far I haven't had smooth water to really try it on. Most of the water is around 20 to 40 ft deep.
guardian667
#30 Post by guardian667 » Wed Aug 20, 2014 8:38 am
2014 sylvan mirage cruise le 20 foot with 115 hp yamaha
29 miles/hr one person
23 miles/hr eight onboard
Propeller 13x15 four blades
