ok i am confused now
rlcrews
#1 Post by rlcrews » Mon Mar 04, 2013 11:27 am
ok i no longer know what to believe now . due to another post here concerning getting lift and how to get that i was steered a way from one in favor of another option . i just visited a website for the pontoon water glide , and read thru an article comparing the 2 different options with the one (tap fins versus strakes) winning .
and this was on the internet so it has to be true right :)
can i getting some clarity on the article with out getting a whipping for bringing this up once again .
ToonGuy
Re: ok i am confused now
#2 Post by ToonGuy » Mon Mar 04, 2013 11:54 am
Use the search feature. Search for Tap Fins in topic titles, and spend the rest of your day reading up on the cons and cons. :lol3
#3 Post by curtiscapk » Mon Mar 04, 2013 12:30 pm
and cons
pond tuuunes
#4 Post by pond tuuunes » Mon Mar 04, 2013 1:14 pm
All the Fast pontoons I see have strakes, I dont even know what a tab fin is. Hope that helps. JT
#5 Post by HandymanHerb » Mon Mar 04, 2013 2:39 pm
We tried for five years to get before and after spec numbers on tap fins, our welding expert on the forum many years back got a set for free and we were finely going get before and after numbers,that was before the days of cheap GPS's so a member was even going to send send his GPS to use in the test, then FusionKing was never heard from again after being our welding expert for years
slingshot
#6 Post by slingshot » Mon Mar 04, 2013 3:06 pm
"Tap Fins"
Uh ohhh :scared :nobrady :deadhorse
2007, 2570 Crest LE II
Yamaha F150
Redneck_Randy
#7 Post by Redneck_Randy » Mon Mar 04, 2013 4:07 pm
The water glide is hard to tune and may need to be removed and reinstalled several times before finding the sweet spot for it to work correctly.
Go with strakes
_______________________
2011 Silver Wave Play 230
Honda BF150
2013 4X4 Silverado
#8 Post by badmoonrising » Mon Mar 04, 2013 10:58 pm
Avoid Tap Fins at all costs. Just sayin' :scared :scared :scared :scared
tuned
#9 Post by tuned » Tue Mar 05, 2013 6:51 am
Although I have a WaterGlide and am quite satisfied with the performance V cost, I must agree with Redneck Randy here. Go with factory strakes. Add-on strakes (flap tins, I mean fap pins, I mean....Tap Fins :biggrin2 ) are just asking for trouble because of the risk of hand welding long runs on thin aluminum.
The WG is groovy but as Randy mentioned, must be carefully tuned. Be prepared to spend a fair amount of time scrunched underneath ur toon.
ToonGuy
#10 Post by ToonGuy » Tue Mar 05, 2013 9:13 am
tuned wrote: (flap tins, I mean fap pins, I mean....Tap Fins :biggrin2 )
You forgot Fap Fins :happy
#11 Post by margaritaman » Tue Mar 05, 2013 10:18 am
Almost any decent pontoon manufacturer will install lifting strakes on their toons but I do not know any of them that will install fap fins.
#12 Post by curtiscapk » Tue Mar 05, 2013 10:34 am
wha tare this fin faps you speak of? :smoke
#13 Post by margaritaman » Tue Mar 05, 2013 11:15 am
These are fins that flap when your go wot becoming wing like and lift your toon out of the water giving the effect of flying. On cruising rpm you hear a tapping sound just like the dance where it got it's name from. :rofl :rofl :rofl :rofl :rofl :rofl
When things start sounding Goofy to you there is a guy called Malcolm that can explain it to you if you can read his spelling. :rofl :rofl :rofl :rofl :rofl :rofl
#14 Post by lakerunner » Tue Mar 05, 2013 12:56 pm
dum't fergot thy mek bening misabld hve a snother rod
Texoma Toon
#15 Post by Texoma Toon » Tue Mar 05, 2013 1:05 pm
I'm not even going there......... :rofl :rofl :rofl :rofl :leghump
2007 G3 LX 22 Fish & Cruise
90 Hp Yammy
Dual Axle Trailer
