Environmentally safe pontoon cleaning
- Ron Burgundy
I keep my boat docked in the water so I don't get many opportunities to clean the aluminum pontoons. Does anyone know of a product that is safe to use while a boat is in the water?
Re: Environmentally safe pontoon cleaning
Ya jump in with a green scrubby and have at it, LOL.
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
- Ron Burgundy
Good idea, but I should have been more specific. The part of the pontoon that is underwater is coated with antifouling paint, and it is pretty clean. The part that I want to shine up is the upper section which is above water.
Now if were a lib I'll tell you to jump in with the buffer plugged in and shine it up, but since your a conservative in training, then don't do that!!!
Sitting in the water you don't many choices except by hand or air tools.
- chill'nthemost
sos pads an pellet rifle for the environmentalist that say you are polluting a gazillon gallon lake with one sos pad.
- Ron Burgundy
Nice we are slowly turning him
He hangs out here long enough, he'll tear up his PETA membership too
Call one of our friends in the frozen north and have them send you one of those 7" wide Lexan ice scrapers. Boil a pan of water, put the working end of the scraper in it, then, with a heavy glove, form it to the shape of your pontoon by pressing it on the tube (holding it at a good working angle). You end up with the perfect scraper to knock off the fouling. It works great on barnacles, moss or those little mussels.
I would avoid anything as aggressive as steel wool or Scotch Brite on your bottom paint.
I imagine the gulf is about 70 up there. I doubt a real Floridian is "jumping in"
Great idea!!GregF wrote:Call one of our friends in the frozen north and have them send you one of those 7" wide Lexan ice scrapers. Boil a pan of water, put the working end of the scraper in it, then, with a heavy glove, form it to the shape of your pontoon by pressing it on the tube (holding it at a good working angle). You end up with the perfect scraper to knock off the fouling. It works great on barnacles, moss or those little mussels.
- Ron Burgundy
It's probably going to be in the 30's tonight again so doubt I'll be jumpin in. Thanks for the scraper tip.
I love animals...they taste great!badmoonrising wrote:He hangs out here long enough, he'll tear up his PETA membership too![]()
What's next, joining the NRA ?
- FloterBoter
too bad you didn't ask before your departure from the dems.
if there are gators in the lake, i'd have told you to jump right in!
