Speed of a 20'
Speed of a 20'
I am wondering what the speed of a 20' pontoon with a 90 hp???
2000 Fisher 200 dlx 20'
2001 Mercury 90hp 2 stroke
- kryptonite
Re: Speed of a 20'
My guess would be around 25-28 mph.
Re: Speed of a 20'
I got 18 on a 20' with a 60hp and wind
-bb
-bb
- brumbyvet.1044
Re: Speed of a 20'
Without strakes probably 22-26 mph.
Garmin 430S
Cherokee Lake, TN
Garmin 430S
Cherokee Lake, TN
Re: Speed of a 20'
My 22' with a 90 hp 4 stroke gets 25 with 2 on board. You should see a little more depending on your weight, I'd say 24 to 28 mph!
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
Re: Speed of a 20'
how fat is your... i mean, how much weight will you be carrying in the boat??
Re: Speed of a 20'
CaptainBob wrote:I am wondering what the speed of a 20' pontoon with a 90 hp???
Hi, I have a 20' Bennington with a 90hp Mercury 2 stroke, 2 people on board I can get 23-25 depending on how calm the water is
Ron
Re: Speed of a 20'
OK just checking if I was doing the same as everyone else and I can do 24 with just me and 23 with the family onboard.
Re: Speed of a 20'
Two toons, whole family on board, calm water, 23 mph. I usually cruise at about 18-20 mph at about 4500 rpm. This is with a 90 hp 4-stroke Suzuki.
2002 Sweetwater 20RE
2002 90 HP Suzuki 4-Stroke
Re: Speed of a 20'
My 22' Sweetwater with 60HP Yamaha 4 Stroke tops out a little over 19 mph spinning 5800 RPMs. That's with the family on board, and I might hit 20 mph under perfect conditions. At 4200 RPMs I run about 14 mph; that seems to be the most comfortable cruising speed.
________________________
We have a water access only camp, so our pontoon is utility first.
1st Toon: 84 Sylvan, 24ft, 03 Honda 4 Stroke
2nd Toon: 2011 Sweetwater 2286, 25in Pontoons, Yamaha T60 4 Stroke
Other Boat: 15ft Runabout w/ 03 15HP Merc 4 Stroke
Re: Speed of a 20'
I got a new 20' with 90hp.CaptainBob wrote:I am wondering what the speed of a 20' pontoon with a 90 hp???
I get 27-28 mph (GPS) with 2 heavy adults. WOT = 5500 RPM Redline = 6000.
The speedo says 30. But I believe the GPS...
Mike
20' Sweetwater with a 90hp Yamaha
Northeast Florida (GCS)
Re: Speed of a 20'
I have a 60hp Big Foot and I get 23-24 GPS WOT with 2 people.
I would guess your gonna get upper 20's with a 90
2008 Lowe Suncruiser 22ft
2008 Merc 60hp Big Foot
Tandem Axel Karavan Bunk Trailer
Re: Speed of a 20'
I have the same setup and do about the same as Lunker. I just don't run WOT very much. It sounds better on the motor to me at ~4400 and that is still 18-19. Fuel economy is better too.
1974 Harris
70 HP 4 stroke EFI Yamaha
Re: Speed of a 20'
I have a 22' with a 90 4st, 27" toons, and got 27.3 GPS with 3 on board and 1/2 tank. You should do better than I do.
Frank
Frank
2008 Crestliner 2185
2009 Merc 90 4 strk
Western Washington
2009 Merc 90 4 strk
Western Washington
Re: Speed of a 20'
GregF wrote:I have the same setup and do about the same as Lunker. I just don't run WOT very much. It sounds better on the motor to me at ~4400 and that is still 18-19. Fuel economy is better too.
Greg F what prop do you have on your 60. I have a 20' Lowe Suncruiser with a Merc 4stroke 60.....I max out at about 17-18 GPS @5300 rpm. Not sure what prop i have now, but i dinged it up a little at the end of last year and am going to replace it soon.
Same question for Lunker also....what prop? (Although mine is not a bigfoot)
