Another Okie
Re: Another Okie
I really hope that was a case of "can't control your typing finger" 6800 @ WOT!!!!!!! Impressive
Wayne and Carla Taylor
Vanvouver, WA.
2005 Suntracker Bass Buggy
60 HP Mercury Big Foot 4 stroke
54# Motorguide trolling motor
2 Hummingbird Fish Finders
03 Dodge Ram 1500 2wd
OF COURSE I TALK TO MYSELF, SOMETIMES I NEED AN EXPERT OPINION
Vanvouver, WA.
Re: Another Okie
6800 RPM at WOT is correct -- although I think it is too high and I need a higher pitch prop. My prop is only 13 pitch, but I had it repaired and the guy repitched it to 14 or 14.5 on the aluminum prop. I'm thinking I need to go to a 16 or 17 pitch so I can get all the horsepower from the motor. I don't like running over 6000 RPM, so that means I shouldn't run WOT at this point till I get a new prop.sgpwayne wrote:I really hope that was a case of "can't control your typing finger" 6800 @ WOT!!!!!!! Impressive
- Redneck_Randy
Re: Another Okie
OK Toon,
Welcome to the forum from a fellow Oklahoman
_______________________
2011 Silver Wave Play 230
Honda BF150
2013 4X4 Silverado
Re: Another Okie
Ok toon... I don't know much " mechanical " when it comes to outboards, but I'm surprised that the rev limit alarm didn't sound @ 6800. I know a factory rep from Yamaha told me that the rev limit on my f75 was 6200 rpm's. with my current prop, I'm just a hair under 6k @ wot.
Re: Another Okie
How long running at the high RPM before you should hear the rev limit alarm? When I looked up the info on the motor, it said the ideal range was 5000 - 6000. So when I took it to 6800, I didn't stay there but for just a few minutes to see what the speed would get too. Then I backed it back down within the ideal range for the motor.
We've only had the boat now a little over a month and I'm still learning everything about it. Maybe it doesn't have a rev limit alarm??? Where would it be? I know it doesn't have any meters to indicate the number of hours on the motor (I verified with the seller on this).
Re: Another Okie
There's no reason why the rev limit function couldn't be automagically managed by the ECM - also there's a lot of good reason to keep the "hour meter" in the ECM as well. With the right software and an NMEA2000 interface, you can read it.OK Toon wrote:Where would it be? I know it doesn't have any meters to indicate the number of hours on the motor (I verified with the seller on this).
