Still no name(Now named "Sunburn")
Re: Still no name(Now named "Sunburn")
Go buy a rotary tip for his pressure washer, it's a zero tip that does about two inches wide as the tip rotates to rip the stuff off.
Got one, I'll give it a try. Thanks!
Michael
Rough River Lake, Kentucky
50 HP 2003 2-stroke Mercury
Got a little more off, but still pretty glued on. Maybe exposed to elements now, that layer will loosen up
Michael
Well stupid me...after swapping the prop, I didn't reconnect the spark plug wires. Went to crank her up today...and guess I over did it cranking. Won't crank now at all...wife's yelling "Sell it!"
Dropped it off at the mechanic, we'll see how much this is going to cost me
Michael
B reakMPosey519 wrote:Well stupid me...after swapping the prop, I didn't reconnect the spark plug wires. Went to crank her up today...and guess I over did it cranking. Won't crank now at all...wife's yelling "Sell it!"
O ut
A nother
T housand
Hope it's not too bad....
bad Starter Solonoid, bad key switch, pinched fuel lines...think that's got it covered
parts on order
parts on order
Michael
New solenoid's in, replaced a couple fuel hoses while I had the cowl off, and the spark plugs were pretty carbon-ed up, so replaced them too.
New ignition switch wired in, thin the old one was blowing fuses(not really a merc switch)
Running well now. To the lake tomorrow!!!
Michael
