miami to bimini to key west to cuba
ericrunner
#1 Post by ericrunner » Fri Nov 11, 2011 3:31 pm
I'm trying to gather info on a possible Miami to Bimini to Key West to Cuba and possibly to Cancun
First i'm a Canadian citizen i dont no if going from key west to Cuba is a problem or not ! I heard all kinds of rumors on going to Cuba by boat but nothing on Cuba to Cancun
Are plan would be , Miami to Bimini first trip
Miami to Key West to Cuba and possibly to Cancun second trip
We will be using pwc
Going to Bimini from Miami i presume i will need to advise the authority before we get there ?
I presume its the same thing for Cuba and Cancun
Anyone as done this trip or parts of it ?
Ron Burgundy
Re: miami to bimini to key west to cuba
#2 Post by Ron Burgundy » Fri Nov 11, 2011 3:36 pm
A friend of mine is planning a trip to Bimini. I'll see if I can get come details.
GregF
#3 Post by GregF » Fri Nov 11, 2011 5:22 pm
Bimini is just a 50 mile hop from Ft Lauderdale, it is actually a lot farther to Key West but Key West will be in more protected waters with the keys on your right assuming you run the short route on the inside.
Key West to Havana is 90 miles, the west coast of Cuba to Cozumel is about 150
If you have a Canadian passport there are no problems with you going to Cuba.
slingshot
#4 Post by slingshot » Sat Nov 12, 2011 5:47 am
Go to www.greenhulk.com which is a PWC site. The South Florida PWC club does that kind of stuff all the time. They'll clue you in on amount of gas needed and best time of year to go. Good luck.
2007, 2570 Crest LE II
Yamaha F150
jafo9
#5 Post by jafo9 » Sat Nov 12, 2011 8:02 am
www.pwctoday.com is another good resource. I've seen several threads talking about those kind of trips. Occasionally, they'll put up some nice videos of their trips.
2002 MasterCraft X30
2007 Yamaha FX HO Cruiser
2005 Kawasaki SXR800
2004 Yamaha SuperJet
1989 Kawasaki 650sx
Lewis Smith Lake, Alabama
#6 Post by Bamaman » Sat Nov 12, 2011 9:09 am
I currently own two PWC's, and have owned "jet skis" for over 25 years.
The open ocean is not a place to do long distance trips on a 9' long boat that's 3' wide. It's not even a place for a 25' pontoon boat, even if it's a heavy duty model tri-toon (with strakes) and a 250 hp motor.
I would prefer to make long distance runs on inland rivers, where there's something to look at. In the open ocean, all you've got to look at is waves. Any mechanical failure would be disastrous without a support boat to back you up.
A large group of PWC's runs the length of the Tennessee River every summer, and they'll have 100+ PWC's. They're supported by fuel boats, as logistics are quite complicated for a 500-600 mile trip. They come back every year, so it looks like they're having a ball.
GregF
#7 Post by GregF » Sat Nov 12, 2011 1:34 pm
People make the Miami to Bimini hop in all sorts of boats. It is best to run with someone else and be sure you have a couple of GPS's plus a good compass. There is a 6-7kt current across that path and Bimini is easy to miss.
You will need a yellow (Quebec) signal flag to fly as you approach and go to customs immediately to check in (aka pay your port tax)
I assume the same will be true in Cuba and Mexico.
Going down the Keys is less of an issue because you can basically island hop the whole way, all the way out to the Marquesses.
The Coast Guard may be with you most of the way to Cuba but you are probably going to be on your own on the way to Mexico.
Ron Burgundy
#8 Post by Ron Burgundy » Sun Nov 13, 2011 11:40 am
I can't speak about the other trips, but the crossing from Miami to Bimini is fairly common in jetskis. I would definalty go with a couple other people and having a support boat is a smart idea.
The current is strong so a pontoon boat (displacement hull) would have trouble staying on course, but with a jet ski (planning hull) it's not that much of an issue.
There are lots of videos on YouTube documenting this portion of the trip. Here is one of them.
GregF
#9 Post by GregF » Sun Nov 13, 2011 1:45 pm
A pontoon will do fine with the current but if you get a little weather you could get in trouble in a hurry. I know a guy who did it this spring, actually all the way to Big Abaco, in a 20' sail boat. He left his boat there and flew back. He is going to commute when he wants to sail around the Bahamas.
Ron Burgundy
#10 Post by Ron Burgundy » Sun Nov 13, 2011 10:08 pm
I just meant that a pontoon boat would take more effort, and fuel, to maintain course in the Gulf Stream than a jetski that just zips over the top of it.
I've been thinking about making this trip with a friend of mine, but still haven't convinced my wife that it's not completely nutz. :drive My dad is probably going to sail there next year. It seems like a good introductory trip in open ocean crossings, but like you said a good GPS is important because it's a small target.
GregF
#11 Post by GregF » Sun Nov 13, 2011 10:51 pm
You really don't know you are in that current. That is why people get it trouble. You can be doing perfect dead reckoning and still miss the islands by 40 miles. The current is still pushing you north at 6 knots and the next stop is Africa. More likely, your wreck washes up on the beach in Nova Scotia.
As long as you understand and plot a vector across the gulf stream you will be OK but you are right, that course will be using more fuel.
Back in the olden days (before GPS) you could still do a good job as long as you had a sextant and could plot your latitude. (the easy one) All you really need to do is find the north star.
Ron Burgundy
#12 Post by Ron Burgundy » Mon Nov 14, 2011 6:49 am
Eric, If you're not planning on going with a support boat you're going to need to build some fuel can holders to bring some extra gas with you. If conditions are perfect you probably won't need it, but if you have to divert because of foul weather you're going to need it. My friend is starting to build his with PVC pipe. I'll try to see if I can get his specs.
In my mind you have 2 main concers...mechanical failures and weather. You can deal with either one individually, but if both strike at the same time it could get ugly. A few guys I know tried this crossing once, but when they got about 10 miles offshore it got very rough and they decided to turn back. Remember The Gambler,..."know when to walk away, and know when to run..."
playcat
#13 Post by playcat » Mon Nov 14, 2011 9:31 am
Check out Avalon's website; they have videos of one of their toons making that trip as well as some other long-distance runs...
playcat
JC 266 TriToon
Kerr Reservoir, VA
Drago
#14 Post by Drago » Sat Nov 19, 2011 8:28 pm
I think I read that story about the pontoon trip from Florida to the Bahamas in Pontoon and Deckboat magazine.
http://www.tahoepontoons.com/info/adventure.html
Kenneth & Joy
Lake Conroe, Texas
2007 Bennington 2577RFSi
2006 Yamaha F225
Solas 14.25x17SS prop
Best ever top speed 69.2KPH
smltooner
#15 Post by smltooner » Sun Nov 20, 2011 2:03 pm
Drago.......you opened a BIG can of worms now.
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
