RPM check?
RPM check?
Does anyone have any tricks for testing your tach for accuracy? I swear mine is not right, I got out on the lake last weekend and at full throttle it sure sounds right but my tachs only showing about 3k rpm... Is there a cheap rpm meter out there that I can clip onto a spark plug cable?
Re: RPM check?
Have you done any work under the helm recently. If so you may have bumped the dial that you adjust for your outboard type.
Sheridan, Indiana
Sheridan, Indiana
Re: RPM check?
I dont think I have messed with anything, I have already checked it a few years ago and it seems to be set properly...Heatman wrote:Have you done any work under the helm recently. If so you may have bumped the dial that you adjust for your outboard type.
