Can't get max power (easily)
mytee_hercules
#1 Post by mytee_hercules » Sun Jun 06, 2010 7:42 pm
I have a 1996 Tracker 120 Force and I can't seem to keep it at full power -- semmingly due to the throttle or cabling or something. The throttle moves freely forward and reverse, but when I push it all the way to max power, if I don't keep pressure on the throttle, the handle moves back a fraction of an inch and the RPMs reduce.
I'm guessing it is a "simple" mechanical fix, but I'm not as familiar with the boat as I would like (took it out for it's 2nd trip last weekend). Anyone have a direction in which to look? Any pictures of if/where the adjustments can be made?
Thanks in advance for the help . . .
Hangin' in Little Rock . . .
1996 Sun Tracker Party Barge 24
1996 Force 120hp 4-cyl 2-stroke
15p aluminum prop
25 mph @ 4800 rpm
Re: Can't get max power (easily)
#2 Post by lakerunner » Sun Jun 06, 2010 9:07 pm
some where on the throttle box should be a friction screw. It might be under the cover if you have a dash mounted shifter as opposed to side mount.
mytee_hercules
#3 Post by mytee_hercules » Mon Jun 07, 2010 1:26 pm
The throttle is a Quicksilver 300 series without the trim buttons . . .
I think it's like a COMMANDER 3000 PANEL (88150A40 THRU A48)
Anyone know how or where to adjust this ?
Anyone have an electronic version of the owner's manual ?
Thanks in advance . . .
15p aluminum prop
25 mph @ 4800 rpm
BassFrequency
#4 Post by BassFrequency » Mon Jun 07, 2010 5:29 pm
mine 60 is doing a similar thing that started today but unfortunatly it aint related to the throttle
60HP Evinrude
#5 Post by curtiscapk » Mon Jun 07, 2010 7:05 pm
brandon,
you know what it is? :donno
BassFrequency
#6 Post by BassFrequency » Mon Jun 07, 2010 7:29 pm
I think i sloshed a gas tank goober or somthing into the system + same spark plugs for 3 years (fouled to hell)
i get speed and power back temporarily when i push the key in for choke.
so it could be im loosing partial spark on one or more cylinders as i still barely hit 5k but its obvious shes loosing some power.
it only does it under load, if its reved in neutral, no prob.
fires right up like a champ but has just an ever so slight rough idle
60HP Evinrude
BassFrequency
#7 Post by BassFrequency » Wed Jun 09, 2010 8:24 pm
got her fixed, runs like a rocket again.
high speed jets were clogging so ended up rebuilding all three carbs ($90 for three kits :shock: )
also found a cracked open gas line where she was inhaling air in the wrong spot.
thats the update :biggrin2
60HP Evinrude
#8 Post by curtiscapk » Thu Jun 10, 2010 6:02 am
Yep ordering my carb kits this coming week. Maybe I can get the 115 to act like something more than a 40 :rofl :rofl :rofl
How hard was it to get em synced?
BassFrequency
#9 Post by BassFrequency » Thu Jun 10, 2010 5:06 pm
curtiscapk wrote:synced?
what do you mean
60HP Evinrude
mytee_hercules
#10 Post by mytee_hercules » Sun Jun 13, 2010 7:37 am
Anyone have this throttle and can help me find the way inside this thing to adjust the throttle ?
:prayer
15p aluminum prop
25 mph @ 4800 rpm
