tilted or level ?
Motor tilted or level when toon is on trailer
Tilted
13
39%
Level
20
61%
Total votes: 33
jim454
tilted or level ?
#1 Post by jim454 » Fri May 29, 2009 7:32 pm
I have a bit of a disagreement with my father-in-law on how a boat motor should be adjusted when the pontoon is on the trailer.
He says it should be tilted up yet he can't give me a reason why.
I have always been told that it should be level as to not put extra stress on the transom, especially when in tow.
What do you guys think?
'99 18' Monark Suncaster
50 hp Honda
Canvas Craft Enclosure
The Mighty Mississippi !!
Snider4
Re: tilted or level ?
#2 Post by Snider4 » Fri May 29, 2009 7:42 pm
I was told to tilt it up to avoid possible damage to the lower unit from the ups and downs of the road,
right or wrong???
Snider4
Misty Harbor 2080RE
Merc 50
Sprinter Select 26BH
Ohio
#3 Post by lakerunner » Fri May 29, 2009 7:48 pm
If I am going to refuel I raise and install transom saver. Otherwise I keep it level
dockholiday
#4 Post by dockholiday » Fri May 29, 2009 7:50 pm
On the bowrider trailer with the motor up. The last two toons trailer with them down.
smltooner
#5 Post by smltooner » Fri May 29, 2009 8:50 pm
Snider4 wrote:I was told to tilt it up to avoid possible damage to the lower unit from the ups and downs of the road,
right or wrong???
I agree with this statement.
I'm not sure how much the difference is in pressure on the transom if motor is tilted up or level.
If you want to be safe when tilting up, use a transom saver.
:2cents
SMLTOONER
Ted & Emily
2019 Bennington 21SL Tri-toon
2019 Yamaha 150 HP
Smith Mtn. Lake, Virginia
FloterBoter
#6 Post by FloterBoter » Fri May 29, 2009 9:02 pm
up with a transom saver.
even with my i/o, i trailer with outdrive up with support strap.
#7 Post by HandymanHerb » Fri May 29, 2009 9:22 pm
Down as it puts less force on the transom, my engine is over a foot off the road so no contact is going to be made with the ground
tkrein
#8 Post by tkrein » Fri May 29, 2009 10:27 pm
i trailer with it level now this will all depend on what style trailer you have a bunk or a sissor style. with a bunk i have never seen any one trailer with it tilted. when i bought ours i asked the same ? they told me that it is up so high with a bunk that you would have other problembs before the motor hit. now sissor you have to be tilted as the pontoon sits close to the ground. thats just what i have seen
2017 Bennington 22ssrx
115 Yamaha
karavan Trailer
2014 Chev tahoe
_________________________
Port Of Bismarck ND
lady on the lake
#9 Post by lady on the lake » Sat May 30, 2009 2:41 am
WHEN MY BOAT IS JUST SITTING ON THE TRAILER I PUT THE MOTOR LEVEL- LIKE YOU SAID, LESS STRESS ON TRANSOM, ETC- WHEN I TRAILER THE BOAT I PUT UP ABOUT HALF WAY SO IT DOESN'T HIT ON THE PAVEMENT IF I GO UP A STEEP INCLINE.
#10 Post by badmoonrising » Sat May 30, 2009 5:50 am
Always up when trailering, down while on the trailer and parked. I don't see how raising it is going to increase stress on the transom as you aren't changing the weight by raising the motor...
Besides, with an I/O you have much more weight in the engine pod to counter the drive's weight. An outboard bouncing up and down on a rough road can damage the transom though, so use a transom saver.
#11 Post by HandymanHerb » Sat May 30, 2009 7:07 am
I/O doesn't have that much weight, but an outboard tilted forward throws the weight sidewards so it can bounce and twist the transom, which is where the transom savers came from, in the down position the bounce is straight up and down
jim454
#12 Post by jim454 » Sat May 30, 2009 7:38 am
I have a bunk trailer so I have plenty of clearance even when I'm towing but it just doesn't make any sense to me to have the engine tilted when the boat is parked and sitting on the trailer. If anything, it's more of an obstacle to back into when it's tilted up.
50 hp Honda
jim454
#13 Post by jim454 » Sat May 30, 2009 3:22 pm
lakerunner wrote:If I am going to refuel I raise and install transom saver. Otherwise I keep it level
What's the reason behind that?
50 hp Honda
mikeherb
#14 Post by mikeherb » Sat May 30, 2009 6:59 pm
Gotta use a transom saver I think. My motor is less than a foot off the ground when down.
I store it down but tilt it with a transom saver when I am towing.
pontoonMoose
#15 Post by pontoonMoose » Sat Jun 13, 2009 10:19 am
I think everyone needs to follow behind there own boat when its being towed. up or down they bounce alot my wife was pulling mine and I was riding with a friend and we were behind the wife. I though for sure the motor and transon were coming off the toon a couple of time's. needless to say. will never tow mine without the transon saver in place. its just cheap insurance and piece of mind.
89 Tracker 24'DL Party Barge
04 Yamaha C-115
Prop 13 3/4 x 14 = 24 mph
Humminbird Matrix 17 W/GPS
Minn Kota Trolling motor
Nissan Titan 4X4
