Hi, i have seen that many times working on these boat motors, ethonal (sp) will eat the plastic lining and cause it to shrink up like that, Also if that is at the end of the line some people in a hurry will shove the end on and the end will push the linining back into the hose and create a block. i had one here that the guy took to the local boat shop 3 times,,,, they cleaned carbs and changed filters and did about 400.00 unnesasary work to the motor when all they had to do is cut off 2" of line and put it on slowly
it took me about 15 min to find it, but i check out all the lines and filters and primer bulbs before i tear into the motor
also check the gas tank vent, i have see mudd dobbers build nests in bunches of them... motor will run great then start slowing down and die because of vacume in the tank after about 15 -30 min it will start again
sorry to ramble on so much........ new here and i need to shut my mouth and sit back and read
PS: i cant spell worth a crap but i can run the hell outa a boat LOL
