Prop pitch
silverfarm
Prop pitch
#1 Post by silverfarm » Wed Jun 10, 2009 7:54 am
I have gone through a couple of tries with new props but can't seem to get it right. Have 20' fisher with a 4stk merc, 60 hp efi (not a bigfoot). Currently running a 101/2 x 12 and can just get to 5k rpm. Seems like I am still missing the top end a bit. Any suggestions?
1997 Fisher 200DLX
2004 Merc 60hp 4stroke
oldmn19
Re: Prop pitch
#2 Post by oldmn19 » Wed Jun 10, 2009 8:29 am
Sounds like you need a 10 pitch to get rpm's up. That will pick up about 200 rpm's om average. But only true test is try it! :2cents
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
mikeherb
Re: Prop pitch
#3 Post by mikeherb » Wed Jun 10, 2009 2:03 pm
You'll increase your RPMs by 150-200 for each one inch reduction in pitch. A 10 pitch would increase your RPMs 300-400.
What is the max RPM for your outboard?
Heatman
Re: Prop pitch
#4 Post by Heatman » Wed Jun 10, 2009 6:00 pm
Sheridan, Indiana
dockholiday
Re: Prop pitch
#5 Post by dockholiday » Wed Jun 10, 2009 6:42 pm
You looking for more rpm or top end speed? Just for comparison I first tried a 17p Mirage and could only turn 5300 and 38 mph.
Next tried a 15p enertia and got 6000 at 40mph. Bottom line I only picked up 2 mph with a 700 rpm increase and that is with a 150 and a 3 log boat. Don't mean to discourage you, but I would not blow a lot of money testing different props unless you have someone that will let you test them for free and exchange them. Might go to a 10p and get the rpm up but end up not gaining any speed or possibly loose speed top end. If I haven't said it before "Welcome aboard"
wwind3
Re: Prop pitch
#6 Post by wwind3 » Thu Jun 11, 2009 8:09 am
dockholiday wrote:You looking for more rpm or top end speed? Just for comparison I first tried a 17p Mirage and could only turn 5300 and 38 mph.
I'm having the opposite problem----13x16 Merc prop and I still hit the rev limiter if I dont watch it. May be the 25 in logs and the underskinning--it planes out pretty quick. 28 GPS altho I hit 30 one day--combo of good lifting headwind and maybe a little ground effect as I was in about 8-10 ft of water. I May add a little cup to the prop----dunno
2009 LOWE SS204 25in logs
90 Merc Optimax
Motorguide W55 Wireless
Underskinning
28 GPS
dockholiday
Re: Prop pitch
#7 Post by dockholiday » Thu Jun 11, 2009 8:48 am
Glad you posted that. The 200 to 300 rpm per pitch is just rule of thumb. Lots of variable also enter into the equation. Size of log, motor position, number of logs, and a bunch more I am sure. One 15p may give totally different result than another 15p even made by the same manufacturer. My guess that is why Merc has so many different props, mirage, enertia, vengeance and so on. I am sure there is a little better prop for mine, but not enough to go searching and buying props and having to resale them.
