Skin the bottom
Thummper3
Skin the bottom
#1 Post by Thummper3 » Mon Jul 06, 2009 11:55 am
Finally got the nerve up to tackle "skinning out the bottom of my toon". I done this over the July 4th weekend. Still have to fab up some end caps for the front where the aluminum starts. But all in all...I think it's a pretty damn good job for a Truck Driver!!!
Snider4
Re: Skin the bottom
#2 Post by Snider4 » Mon Jul 06, 2009 12:31 pm
Looks good, do you hire out?
How big is your merc and how much did it improve your ride??
Snider4
Misty Harbor 2080RE
Merc 50
Sprinter Select 26BH
Ohio
dockholiday
Re: Skin the bottom
#3 Post by dockholiday » Mon Jul 06, 2009 1:39 pm
Looking good.............
Thummper3
Re: Skin the bottom
#4 Post by Thummper3 » Mon Jul 06, 2009 4:06 pm
Snider4 wrote:Looks good, do you hire out?
Sorry NOT 4 HIRE! Not enough beer to do this again. I had my 115 Merc put on the boat when I bought her.
KenR
Re: Skin the bottom
#5 Post by KenR » Mon Jul 06, 2009 4:43 pm
Really good looking job. How thick was your skinning material?
KenR
1996 Tracker Bass Buggy
Merc 75
Wichita Falls, Texas
Re: Skin the bottom
#6 Post by badmoonrising » Mon Jul 06, 2009 4:58 pm
Nice job, something I've been meaning to do to the PC. Jim, our friend from PDB did his and he says there's a very noticable improvement in performance after underskinning.
oldmn19
Re: Skin the bottom
#7 Post by oldmn19 » Mon Jul 06, 2009 6:51 pm
I don't know, see lots of wrinkles, LOL, just kidding, looks damn fine, for a truck driver, or anybody else! :2cents
Let us know what improvement you notice when you get it wet again. What gauge was it? :ten
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
jim454
Re: Skin the bottom
#8 Post by jim454 » Mon Jul 06, 2009 6:59 pm
I imagine skinning really helps in performance if you're riding low in choppy water.
Keep us posted on the changes it made.
'99 18' Monark Suncaster
50 hp Honda
Canvas Craft Enclosure
The Mighty Mississippi !!
mikeherb
Re: Skin the bottom
#9 Post by mikeherb » Mon Jul 06, 2009 7:02 pm
Looks great.
How thick was the aluminum and where did you buy it?
mrmjbenn
Re: Skin the bottom
#10 Post by mrmjbenn » Mon Jul 06, 2009 8:27 pm
Wow, looks really great. I'm really new to pontoons, what will this do for you, will it help with cruising? will it save the platform?
:usa
MrGadget
Re: Skin the bottom
#11 Post by MrGadget » Tue Jul 07, 2009 5:19 am
What will this do?
Your pontoons drive water up against all the surfaces under the boat. Any vertical surfaces that the water hits (for example cross members) receives opposing force from that, effectively pushing back on these surfaces, resulting in drag. Skinning covers all the cross members so the drag effect is removed or substantially reduced. Also, the aluminum layer adds structural strength to the whole boat, less twisting or torquing when going over waves and wakes, so that should translate into longer boat life in general.
It's hard to see from the pics, but generally the sheets are put on back to front, overlapping them where they meet at the edges under a cross member so water isn't driven between the edges. You don't want to weld them, but screw or bolt them to the cross members as was done here, so if water does get up in there it can drain.
Nice Job!
MrG
2006 32x10 Custom River Cruiser "Regardless"
2007 Evinrude E-Tec 250 2-Stroke
2003 Sea-Doo GTX Limited Supercharged
Ohio River - Evansville, IN
Thummper3
Re: Skin the bottom
#12 Post by Thummper3 » Tue Jul 07, 2009 6:44 pm
Thanks all, I am taking her out this weekend and will let you know if there is any difference. Before I could feel the wake hitting the bottom of the floor and floor joists. The alum. is 16 gauge, and I got it from a metal fab shop here in town. I bought 2 sheets 4x10 at $93 a sheet and 1 sheet 4x8 and had them bend it for the corners and that was $80.50 for that.
Tax and all $335.00 .....not including the beer!!!!! :drink
Thummper3
Re: Skin the bottom
#13 Post by Thummper3 » Tue Jul 07, 2009 6:48 pm
MrGadget wrote:
What will this do?
Nice Job!
I couldn't have said it any better!!!!! But I didn't overlap, I butted them together :hammer
crankshop1000
Re: Skin the bottom
#14 Post by crankshop1000 » Wed Jul 08, 2009 5:28 am
I did my 20 foot Sweetwater last year and it was well worth the effort. I used light gauge galvanized steel from a local heating and cooling shop.I figured the crossmembers were galvanized steel anyways, so galvanized being a lot cheaper as well as a lot stronger was my choice. I have not seen any rust forming and do not have a noise problem either. So galvanized is an option to consider. Chuck.
Thummper3
Re: Skin the bottom
#15 Post by Thummper3 » Wed Jul 08, 2009 5:33 am
I used alum. on the bottom of mine, as the framework is alum. I also put a thin strip of foam gasket dowm each floor joist before I installed the alum. so that the sheets would not vibrated on the joists. Haven't been in the water yet, Hope my idea keeps the noise down. She will get wet this weekend at Robinson Lake.
