Project Twin
Re: Project Twin
#106 Post by Bryden24shp » Wed Jun 18, 2014 6:23 pm
Lookin good Ty!!!
ToonGuy
Re: Project Twin
#107 Post by ToonGuy » Thu Jun 19, 2014 5:09 am
Thanks! Props back yesterday, installed. Under skin finished, loaded the necessary ropes/anchors/safety equipment/PFDs, registration & numbers installed, oil tanks filled...Just waiting on my fab guy to finish 2 more small things. He's really under the gun right now so I'm just PRAYING he gets done by Friday so I can finish up Friday night, gas her up on the way to the lake ($$$) and launch Saturday.
:prayer :prayer :prayer
If I don't get in Saturday my next free day isn't till the 4th :cry: :cry: :cry:
Re: Project Twin
#108 Post by curtiscapk » Thu Jun 19, 2014 5:55 am
:prayer :prayer :prayer :prayer :prayer Let's go Ty!
Mrtoler
Re: Project Twin
#109 Post by Mrtoler » Thu Jun 19, 2014 2:09 pm
Don't forget to take plenty on water pics! I'd like to see how she sits with those twins!
2006 dodge ram quad cab
Crosby Texas
ToonGuy
Re: Project Twin
#110 Post by ToonGuy » Fri Jun 20, 2014 5:18 am
IF I get it wet this weekend it will just be a day trip shake down. I'll need to pull it back out for the mooring cover. Plus I fully expect SOMETHING to need tweaking :lol3
Besides, it's not looking good right now...my fab guy is looking at Saturday morn till he gets my parts finished :cry:
Re: Project Twin
#111 Post by curtiscapk » Fri Jun 20, 2014 9:12 am
DAAAAAAAAAAAAAAAANG :x
Re: Project Twin
#112 Post by RcgTexas » Fri Jun 20, 2014 9:33 pm
Seems triple toons are just triple trouble. I'm living it now as well. Delays after delays then I get started. I can imagine the problems and "adjustments" you are experiencing with the "Twins".
Good luck and I'll keep checking in.
ToonGuy
Re: Project Twin
#113 Post by ToonGuy » Mon Jun 23, 2014 5:16 am
Didn't get my parts. Real bummer too because my next free day is July 4th, and not real sure I want to test it out on the holiday. Oh well no point in staying upset about it, it is what it is. After I've come this far there's no point in rushing it. Might as well get it right the first time.
Re: Project Twin
#114 Post by curtiscapk » Mon Jun 23, 2014 5:57 am
Bummer Ty... :cry:
tuned
Re: Project Twin
#115 Post by tuned » Mon Jun 23, 2014 9:06 am
Misery loves company it seems. As I have yet to take an actual pleasure cruise.
It'll get better, bro. Both boats are worthy.
fergusmj
Re: Project Twin
#116 Post by fergusmj » Mon Jun 23, 2014 10:30 am
Might as well take more pictures for everyone then :thumbsup
Hope things get better for you.
Ferg's Tritoon Build
ToonGuy
Re: Project Twin
#117 Post by ToonGuy » Mon Jul 14, 2014 5:36 am
OK Ferg...I'll post some pics just for you :lol3
I believe I finally have my steering woes figured out, thank you all for the suggestions. As I stated in my other post, I actually got the boat wet! It floats! It runs...sorta. As expected, I ran in to some MORE issues:
I had one trim gauge not working, now both don't work.
One volt gauge reads about 2v low (already knew about that I guess).
Not propped correctly (more on this issue below...).
Low oil warning on port side motor (I'm guessing ((HOPING)) it's the sensor).
Mismatched lower units!
I had to replace one lower unit, and it appears I purchased one with a different gear ratio then the counter rotation motor! As it's propped now, the best I could get out of the port motor was about 4800RPM. The starboard motor would only turn about 4200RPM. I'm guessing when I purchased the replacement lower off of ebay, I got one with a lower gear ratio. Admittedly, I had done zero research on this. When I was searching for a unit, I didn't see any one listing the ratio so I foolishly assumed all these 25" Off Shore units were the same.
As far as the props, I figured the 23s would be a little steep for the boat, but I got them locally for a song so I figured it would be a good starting point since I had no props what so ever. And since I'm sure most of you are wondering, before cutting my day short with the oil buzzer, the best I saw was 46 MPH at the above RPMs. If I had to guess, I believe this toon set up correctly would run 60-65 MPH. That number is with both tanks full, most gear on board, and 2 adults. The rear of the tubes sit a little over half way out of the water at rest.
Time to decide where to go from here...
ToonGuy
Re: Project Twin
#118 Post by ToonGuy » Mon Jul 14, 2014 5:38 am
Some more...
ToonGuy
Re: Project Twin
#119 Post by ToonGuy » Mon Jul 14, 2014 5:40 am
And some night shots...
Re: Project Twin
#120 Post by curtiscapk » Mon Jul 14, 2014 6:02 am
wahoooooooooooooooooooooooooo! :nana You are getting closer! Sounds like fairly minor stuff (hopefully) Except for the lower unit of course I would think you want them matched to run efficiently.... :bowdown :bowdown :bowdown 46 is cooking even with the issues.
