Fill befoe stablizing?
GGALVIN
#1 Post by GGALVIN » Sat Oct 03, 2015 12:47 pm
Should the gas tank be filled before stabilizing for the winter storage or leave space in the tank?
Gonefishing
Re: Fill befoe stablizing?
#2 Post by Gonefishing » Sat Oct 03, 2015 1:38 pm
When I store mine for winter I add the stablizer fill the tank and run the motor with muffins on just to run stablizeres fuel through the motor. But I also always add a stable riser to my fuel during the season also while in use.
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
Strake
#3 Post by Strake » Sat Oct 03, 2015 2:03 pm
I prefer to add the Stabil FIRST, then fuel up as that gets it mixed well. I then drive the boat home and put it up on the lift. The 10 minute boat ride gets the fuel run through the entire system. The head mechanic at my dealership has suggested to me to have about 3/4 of a tank of fuel when I stop for the season and put it up. The gas I am able to buy is NON ethanol so that also helps....
"Strake"
Richard and Angie
Smith Mountain Lake, VA
2015 Berkshire 233 RFX STS
Yamaha F200 LB
teecro
#4 Post by teecro » Sat Oct 03, 2015 3:51 pm
GGALVIN wrote:Should the gas tank be filled before stabilizing for the winter storage or leave space in the tank?
The fuller the tank the less air space you leave. Air space increases the chance for the fuel to interact with the air causing oxidation, also the increased air space increases the chance for condensation too...
#5 Post by lakerunner » Sat Oct 03, 2015 6:14 pm
Gonefishing wrote:When I store mine for winter I add the stablizer fill the tank and run the motor with muffins on just to run stablizeres fuel through the motor. But I also always add a stable riser to my fuel during the season also while in use.
I think muffins would clog cooling ports
#6 Post by Bryden24shp » Sat Oct 03, 2015 11:23 pm
Bagels will take out T-stats, right now!
Gonefishing
#7 Post by Gonefishing » Sun Oct 04, 2015 9:12 am
Bryden24shp wrote:
I agree LOL not good to use muffins. Hope. He know what I did mean. Dam keyboard
2013 115 Yamaha
