1994 johnson 90 hp
1994 johnson 90 hp
hello, having trouble finding proper rpm range for a 1994 90 hp Johnson v4 2 stroke. I'm getting conflicting rpms from different marinas , from 5000 red line w.o.t to 5750 rpm tried the search engine, google ect Help? thank in advance
1992 21ft suntracker party barge 90 hp Johnson
Re: 1994 johnson 90 hp
numbfingers wrote:hello, having trouble finding proper rpm range for a 1994 90 hp Johnson v4 2 stroke. I'm getting conflicting rpms from different marinas , from 5000 red line w.o.t to 5750 rpm tried the search engine, google ect Help? thank in advance
Same as my 98 ,4500 to 5500 with 5000 being where the rated HP is at. If you can get it propped to run 5000 or a bit less at WOT you should be good.
JD
1994 Starcraft Stardeck 200
1998 Johnson 90HP
98 5.9 V8 Magnum Dodge Ram
1998 Johnson 90HP
It should be around 5000-5500.. 100%..
Thank you both for the input. Will keep it in that range. thought 5750 seemed high again thank you
Most of the 2 strokes of that vintage were 5500 rpm motors.
