I want to redo my fencing. I was going to paint it but I see where some have applied "solid vinyl" instead of painting. Where can I get the "solid vinyl" and how is that done?
buster
Solid vinyl for fencing
Olustee bus
Re: Solid vinyl for fencing
If you mean oracle 651 etc, you dont want to do that...you would have to measure/template each section. Then it is a big sticker basically any air, twist etc will be a wrinkle check out what I did, used rolled on paint and simple graphics you could simple lines, swoops etc. The "Big Stickers" not full panels are a lot easy to get on.
oops, didn't see you had 2 threads
Olustee bus
I am going to roll and tip. How much paint did you use?
1-1/2 qts rustoleum, 2 coats outside only. Inside hasn't been done yet
