1) I had a new prop on the motor after rebuilding the lower unit. I think I picked the wrong prop
2) The back of the toon was sitting very low after adding the weight of the motor and gas tank.
3) Water was soaking and splashing and spraying up on the gas tank, batteries, and whole back of the toons.
(do you think raising the motor a bolt hole or two could help with this?
