Fuel Tank Relocate Anyone Done This?
Last year i had a slight cavation issue and a lean issue with just a few people to one side. Been racking my brain and since we dont use the privacy room but for storage I thought I would try to relocate my fuel tank to the center of the toon instead of the side. Has anyone tried this?
2004 Sun Tracker Party Barge 22 XP3 Regency
115 mercury
Tri-Toon with Strakes
2004 F-250 Powerstroke
Wabash and White Rivers Mt. Carmel IL
115 mercury
- BassFrequency
Re: Fuel Tank Relocate Anyone Done This?
I havnt re-located one but ive added one similar to what your describing. (a tank on both sides, a 15 and a 20 gal.)
its pretty easy to do, i'll post some pics of my install later tonight to help guide you
60HP Evinrude
60HP Evinrude
Ours came from the factory with a 29 gal. fuel tank smack dead in the middle right in front of the motor. It should be an easy and practical move I'd think and fairly easy to pull off.
The fuel tank is behind the curtain.
It still allows a walk through to back of boat.
What i got is all under the sundeck. to the right 3rd of it is the 30 gallon tank. then a devidor then a small box with both batterys and storage. what im thinking is to mover the tank to the left side witch is the middle of the boat and useing the right side for storage. and batterys. just not sure what problems i may run into or if this may throw off the balance on the boat for some reason.
- 6570_237336265513_521380513_8583306_4009947_n.jpg (40.21 KiB) Viewed 8121 times
115 mercury
115 mercury
the pic of the back of you boat is how i want to do mine . only thing different is that mine has a solid back
115 mercury
115 mercury
The boat I pictured has the storage under the right outside just above the toon. We keep some life-jackets and bumpers (light stuff) in that storage area. You see the pull op cushion in the middle of your back seating area, anyway that's where the batteries are installed also dead in the middle of boat in front of fuel tank. Makes for a well balanced boat as far as the necessary heavy on-board fundamentals go.
that really annoyed me about my suntracker (05 regency with the I/O). with a full tank i noticed it listed to port and i felt i had to countersteer to keep a straight heading. where would you put the fuel filler and breather hoses if you centered the tank?
2002 MasterCraft X30
2007 Yamaha FX HO Cruiser
2005 Kawasaki SXR800
2004 Yamaha SuperJet
1989 Kawasaki 650sx
Lewis Smith Lake, Alabama
1989 Kawasaki 650sx
I would have to extend the hoses across to the tank. Shouldnt be hard just a trip to napa. I think it will really help.
115 mercury
115 mercury
- FloterBoter
i don't think it will make much difference. you're only at full for a short time, and even then it's only 180 lb. they are often placed on the opposite side of the captain's helm to balance the weight of the captain. i would just have one person move to starboard to balance things. we have a 50 gallon tank on the aft port side and seldom have a problem.
in my ponton they did that also except I have the gli where the transom pod is farther back so it dosent tuck the motor under the sund deck any way they just extended the hoses ran a water seperator. i think this is how most manufacturs are going go check out a new pontoon and see how they did it get som more ideas
2017 Bennington 22ssrx
115 Yamaha
karavan Trailer
2014 Chev tahoe
_________________________
Port Of Bismarck ND
115 Yamaha
karavan Trailer
2014 Chev tahoe
Port Of Bismarck ND
Is it just me or is trott46's avatar fricken huge? heh
Colorado Springs, CO.
lol Yeah it is i cant figure out how to down size it enough to be a normal pic
115 mercury
115 mercury
figured it out
115 mercury
115 mercury
Haha! Sweeet!
- FloterBoter
yeah that was a well hung toon.
not any more though.
