16 MPH
TweetyBird
Re: 16 MPH
#16 Post by TweetyBird » Wed Jun 02, 2010 7:12 pm
I called the dealer today, they called tracker, tracker said the boat should go at least 25. They had me get the numbers off the prop, which are MD 13 3/4 X 15
I will see what they say. Does this prop sound right?
WaltF
Re: 16 MPH
#17 Post by WaltF » Thu Jun 03, 2010 8:37 am
With the lifting strakes that thing so be going way faster.
Id guess once up on the strakes you could hit 30.
Either youre not measuring right or something is wrong.
Are you tooning up at altitude? Ours runs slower up here in Colorado.
Sounds like you need a smaller prop...
Each 1 degree drop in prop = 200 rpm gain.
Id drop that prop to a 11 pitch, so like a 11x15 or so....
Ill bet that would give you MUCH improvement... :nana
Colorado Springs, CO.
TweetyBird
Re: 16 MPH
#18 Post by TweetyBird » Thu Jun 03, 2010 7:01 pm
Talked to the dealer again today, he is gonna talk to tracker, I will call them again tomorrow.....I will keep you posted
wed
Re: 16 MPH
#19 Post by wed » Fri Jun 04, 2010 4:14 am
Have you worked with the trim? Does trim have any affect at all on the boat while you are underway?
2007 GMC Sierra
Oldboater
Re: 16 MPH
#20 Post by Oldboater » Fri Jun 04, 2010 8:16 pm
I agree with others, my 22 foot Starcraft will do at least 27 mph (GPS speed) with 2 aboard and over 20 mph with 8 people with a 90 HP Yamaha.
2010 Starcraft Limited 226 RE CR (22 foot)
90 HP Yamaha 4 Stroke
Ocean City, Maryland
TweetyBird
Re: 16 MPH
#21 Post by TweetyBird » Sat Jun 05, 2010 5:46 am
Yes, the trim has no effect. I am taking it in today, they are gonna check it over, and lake test it. I will keep you posted.
wrenchendave
Re: 16 MPH
#22 Post by wrenchendave » Sat Jun 05, 2010 8:20 pm
i have same prop, same motor, on 21ft 5700 rpm 26mph no lifting strakes though
21 ft 2009 suntracker/90optimax
timmac
Re: 16 MPH
#23 Post by timmac » Mon Jun 07, 2010 12:29 pm
TweetyBird wrote:I called the dealer today, they called tracker, tracker said the boat should go at least 25. They had me get the numbers off the prop, which are MD 13 3/4 X 15
Thought I would add something here, my new 30hp merc on my boat was not getting max rpm, so I removed cover and found that linkage was not adjusted correct to get max throttle, I adjusted it to max and it raised 200 more rpm's, not a lot but you should look there 1st,
however my rpm's are still only 5000 when I should be at least 5200+, my next step will be another prop.
clee
Re: 16 MPH
#24 Post by clee » Fri Jun 18, 2010 10:40 pm
DON'T FEEL BAD I HAVE A 2007 SUNTRACKER REGENCY WITH A MERC 115 OPTIMAX, I AM CURRENTLY USING A 13.5 X15 PROP, I HAVE TRIED 12, 14, AND 17 PROPS, AND STILL GET 21-22 MPH....SLOW BOAT, I WA TOLD THE ENGINE MAY BE MOUNTED TO LOW, BUT OUR TRANSOM HAS A FEW IN DROP IN THE DESIGN WHICH LOWWRS THE ENGINE......WHO KNOWS I WAS GOING TO BUY A SS 14X15 TURBO PONTOON PROP, BUT I DO NOT KNOW HOW MUCH MORE IT WILL GIVE ME.....ANYONE ELSE WITH A TRACKER????
CHRIS :nono
TweetyBird
Re: 16 MPH
#25 Post by TweetyBird » Sat Jun 19, 2010 5:42 am
The dealer is buying the boat back from us. They have been good to work with. We are supposed to have a check within 10 days. The next boat we buy, we will most certainly take a test ride first.
WaltF
Re: 16 MPH
#26 Post by WaltF » Mon Jun 21, 2010 11:41 am
Hey Clee,
Were driveN a 22 foot 2007 regency, 135hp i/o.
We top out around 25-30mph if less then 4 peeps on board...
Sure wish we had strakes, but they didnt offer em that year....
Prop could hit 35-40 if i had em....
Still... didnt buy it for speed...
They dont call it the Party Barge for nothing! :drink4 :rofl :tassles :nana :smoke
mjlyn
Re: 16 MPH
#27 Post by mjlyn » Mon Jun 21, 2010 1:47 pm
TweetyBird wrote:The dealer is buying the boat back from us. They have been good to work with. We are supposed to have a check within 10 days. The next boat we buy, we will most certainly take a test ride first.
Huh, thats interesting.....guess they figure they'll just sell it to someone else who might not think there's a problem...are they trying to sell you another boat or just buying yours back?
TweetyBird
Re: 16 MPH
#28 Post by TweetyBird » Mon Jun 21, 2010 7:35 pm
They are just buying it back. They have an identical boat there they tested, same thing...16MPH
