Adding a 3rd toon
slycustom
Adding a 3rd toon
#1 Post by slycustom » Wed Jun 23, 2010 10:20 am
What would be the pros and cons of adding a 3rd toon I have 1998 25 ft sun tracker thanks for any info.
Re: Adding a 3rd toon
#2 Post by HandymanHerb » Wed Jun 23, 2010 10:23 am
Pro more floatation, so more people can be on board, will sit higher in the water and not plow as much.
BassFrequency
#3 Post by BassFrequency » Wed Jun 23, 2010 10:42 am
put one on mine and gained a smoother ride and before my top speed was 17-18mph after log install, 21-22mph
my center log is only 12' as to not disturb water to the prop
60HP Evinrude
WaltF
#4 Post by WaltF » Wed Jun 23, 2010 11:00 am
Pros - smoother ride, more buoyancy, more speed.
Cons - it cost money.
:nana
Colorado Springs, CO.
dockholiday
#5 Post by dockholiday » Wed Jun 23, 2010 11:03 am
Welcome
Lots of pros. The only con I see would be cost and having it properly installed. Have heard mixed reviews on the water glide, most dealt with the install it seems.
BassFrequency
#6 Post by BassFrequency » Wed Jun 23, 2010 11:25 am
WaltF wrote: Cons - it cost money.
:nana
what don't? :? :rofl
60HP Evinrude
mike
Site Owner
#7 Post by mike » Wed Jun 23, 2010 11:53 am
Some have added a larger and/or lower mounted third toon to give you a bit better handling as well but you may want to be careful with this... I think three pontoons is an overall better way to go... Better safety, stability and capacity for your boat! :nana :nana
JC7274
#8 Post by JC7274 » Wed Jun 23, 2010 2:42 pm
OK, my logs are 25' long and 26" wide. If I added a third log, would it need to be the same diameter and only 15' or so long?
2002 24' Parti Kraft w/90 hp Honda
Boat at Center Hill Lake
