Center Toon Questions
- FloterBoter
Those of you who bought tritoons or added a log:
1. How much larger is the diameter of the center log than the side logs?
2. How many inches lower is the bottom of the center log than the side logs?
3. To get rid of butt-in-the-water syndrome, I assume best to remove the glide thingamajig and run the center log all the way near the back--how far from the lower unit to avoid flow issues?
Not sure who made the boat.
Re: Center Toon Questions
On my Premier with PTX package, the center toon is listed as 36" (U-shaped) and the outside toons are listed as 27". You may or may not be able to tell in this pic, but the bottom of all three toons are just about even. The center toon has a 12" flat "planing surface" that the boat comes up on (and you can really notice it), while the two outside toons are round with inside lifting strakes, but if I were to put a straightedge across all toons, I doubt there is much difference overall.
Please excuse the yellow rope in the picture. I had to store the boat outside this past winter and I had fashioned a cover from one of those temporary carport thingies, and had it tied to the boat and to a temporary fence post at the windward end of the boat at the time the pic was taken.
- rear view premier ptx toons
- stick_premier_rear_toons.jpg (31.48 KiB) Viewed 3585 times
220hp 4.3L mpi Merc
Beautiful southwestern Ohio
220hp 4.3L mpi Merc
dockholiday
All three are same dia, the middle toon is about 4ft shorter. strake inside an out on all toons.
outer tubes 23"
Center tube 27" and set 5" lower.
Strakes on all six sides.
center tube about 1 foot longer (in front) than side tubes and extends back to integrated transom
175 Yamaha VMax
2016 Ford F150
175 Yamaha VMax
2016 Ford F150
- FloterBoter
great info, thanks for the quick replies!
all toons the same size 26" and set level. center toon starts a foot after the outer toons and stops about a foot shorter then the outer toons then has the transom strakes on the inside of the outer toons and on the center toon
2004 Sun Tracker Party Barge 22 XP3 Regency
115 mercury
Tri-Toon with Strakes
2004 F-250 Powerstroke
Wabash and White Rivers Mt. Carmel IL
115 mercury
I don't have a clue.
13 Blazer outboard jet boat
11 12ft Perception Kayak
18 250 6.7 powerstroke
- BassFrequency
all 23" dia. outer tubes 26' center tube 12' with strakes - 5" above outer logs
60HP Evinrude
60HP Evinrude
- FloterBoter
wow, there sure is a lot of variation.
hey bassfreq, is your short center log (geesh that sounds personal) mounted back as far as possible? is the idea to raise the hind end?
- BassFrequency
FloterBoter wrote:wow, there sure is a lot of variation.
nope, its behind the outers by only 2'
keeps it from submarining
60HP Evinrude
60HP Evinrude
26" outboard, 29" center.
All even across the stern, center ends in transom and is 3" deeper in the water.
MrG
2006 32x10 Custom River Cruiser "Regardless"
2007 Evinrude E-Tec 250 2-Stroke
2003 Sea-Doo GTX Limited Supercharged
Ohio River - Evansville, IN
