Where do you tie your anchor rope?
BassFrequency
Re: Where do you tie your anchor rope?
#16 Post by BassFrequency » Sun Jul 25, 2010 7:49 pm
badmoonrising wrote:Where do you tie your anchor rope?
to a polititians feet :devillol and then drive away :rofl
60HP Evinrude
Cobra427cable
#17 Post by Cobra427cable » Tue Jul 27, 2010 9:32 am
I use a 35lb navy anchor on the bow and a 15lb mushroom on the stern to keep it from swaying around. I have noticed though that on a moderatly windy day, I cannot get my anchors to hold. My lake is a muddy bottom and it's very frustrating sometimes. I may not let enough rope out sometimes and have the angle too steep for it to work properly I suppose. I've been eyeballing a Digger anchor that has rave reviews plus it's lighter- any opinons on this anchor? Also, I just tie off to my fencing in the front/rear and it seems very study, maybe I shouldn't do that??
2008 Sun Tracker Regency
22' party barge w/NV logs
135 HP Mercury Optimax
Kaw Lake, Ponca City, OK.
Outlaw67
#18 Post by Outlaw67 » Tue Jul 27, 2010 11:01 am
The key to setting the anchor so it stays is having a 2-3' length of chain between the anchor and the anchor rope. This keeps the anchor at the proper angle to the lake bottom for it to dig in.
You should be able to get by with a much lighter anchor if you use the chain. Some people I know have used anchor as light as 6 lbs. with the chain, anchoring in mud and haven't had any problems.
2006 224 Suncruiser
2006 115 hp Merc Optimax 2 stroke
GXPWeasel
#19 Post by GXPWeasel » Wed Jul 28, 2010 6:05 am
I have a 35lb. fluted mushroom anchor, with 6ft. of chain, and 100ft. of rope. I have yet to budge when setting this anchor for my 26 footer, in moderate winds. I used the exact same anchor last year, with 50 ft. of rope, and it wouldn't hold my toon still on a calm day. The Chain, and correct rope lenght make a huge difference.
"Nauti Weasel"
2005 Beachcomber Islander 26
#20 Post by badmoonrising » Wed Jul 28, 2010 10:17 am
GXPWeasel wrote: The Chain, and correct rope length make a huge difference.
Yep, I use chain on both my boats. Highly recommended.
Brandon
#21 Post by Brandon » Wed Jul 28, 2010 7:05 pm
Any kind of Chain that you can get at like Lowes?
I dont mean that silly stuff you hang a Chandelier with, I mean any kind of Industrial chain would work? To be able to anchor the proper way is huge for me since there is a strong current in my lake. It would make the day on the lake alot more enjoyable for me.
2014 Veranda 22ft
Yamaha High Thrust 115hp
2011 Dodge Ram 1500
I will keep my Guns
I will keep my money
and you can KEEP THE CHANGE!!
America will never be destroyed, if we falter it will be because we destroyed ourself- Ab. Lincoln
FloterBoter
#22 Post by FloterBoter » Wed Jul 28, 2010 9:26 pm
i'm lazy, i just tie it off to a rail. been doing it for years, never bent anything.
as for anchoring from the aft, not as bad in a toon as in a v hull.
i suppose a tri toon would be worse than a 2 toon, but i've still got a 2 toon.
so i choose fore/aft based on putting my butt in the shade.
rcl700
#23 Post by rcl700 » Thu Jul 29, 2010 8:11 am
I USE THIS ANCOR OFF THE BACK TIED TO THE RAIL. CHAIN HELPS KEEP THE ANCOR DOWN HELP A BUNCH. YOU NEED ALOT OF LINE THOUGH. AT LEAST DOUBLE THE DEPTH MORE IS BETTER.
USUALY USE A SMALL MUSHROOM ANCHOR OFF THE FRONT TO KEEP IT FROM SWINGING
1992 Landau Bandit 20' pontoon
2004 Tohatsu 90hp TLDI
24v lenco wireless drive
