Starting with Muffs
Brandon
Starting with Muffs
#1 Post by Brandon » Mon Aug 02, 2010 10:50 am
Well, since the weather was horrible this weekend we were unable to take the boat out, and since it has not been started in two weeks I hooked up the muffs an hour or so after I changed the Gear oil. I started the motor and everything was find I let it idle for a few minutes while I cleaned up. I then started to notice after about 5 or 6 minutes of running that it started to smoke a bit, I was just wondering if this was normal at all or if there is any reason to worry.
The Gas that is in it has been in there for about 2 weeks just sitting, I dont know if that has anything to do with it, but I think its worth the mention
2014 Veranda 22ft
Yamaha High Thrust 115hp
2011 Dodge Ram 1500
I will keep my Guns
I will keep my money
and you can KEEP THE CHANGE!!
America will never be destroyed, if we falter it will be because we destroyed ourself- Ab. Lincoln
jmwhite
Re: Starting with Muffs
#2 Post by jmwhite » Mon Aug 02, 2010 10:56 am
More information would be of help. Engine year, make, and hp. Where was the smoke coming from? Smoke color?
WaltF
#3 Post by WaltF » Mon Aug 02, 2010 12:22 pm
Mighta just been burning off some junk...
Colorado Springs, CO.
Brandon
#4 Post by Brandon » Mon Aug 02, 2010 12:40 pm
50 hp Merc 2000. The smoke was white, and I cant really tell you where it was coming from, I cut the motor off when I saw it
2014 Veranda 22ft
2011 Dodge Ram 1500
I will keep my Guns
Ghost Rider
#5 Post by Ghost Rider » Mon Aug 02, 2010 5:38 pm
Did you have a good sream coming out the pee hole. Most likley just exhaust smoke. I would not worry.
Ghost Rider
1976 20 Foot Flote Bote
40 HP Mercury 4 Stroke
Home : Channahon Illinois
Boating on Cory Lake in MI
slingshot
#6 Post by slingshot » Mon Aug 02, 2010 5:49 pm
Are you sure that it wasn't steam? If you started your motor cold it would take a few minutes before it got up to operating temperature at which time the thermostat would open and allow steaming hot water out the exhaust hub.
2007, 2570 Crest LE II
Yamaha F150
Brandon
#7 Post by Brandon » Mon Aug 02, 2010 7:02 pm
There was steam, however there was smoke also. Its not like there was tons of smoke it was actually kinda hard to tell what was steam and what was smoke. When I seen the smoke I just turned the motor off I just wanted to make sure it wasnt something major.
2014 Veranda 22ft
2011 Dodge Ram 1500
I will keep my Guns
#8 Post by lakerunner » Mon Aug 02, 2010 7:29 pm
Would sure help if members would add to the signature line the make and type of motor and boat you have. We can't remember if you have a 2 or 4 stroke or I/O
Brandon
#9 Post by Brandon » Tue Aug 03, 2010 10:51 am
Your Right Lakerunner, I should have done that a long time ago
2014 Veranda 22ft
2011 Dodge Ram 1500
I will keep my Guns
#10 Post by lakerunner » Tue Aug 03, 2010 11:50 am
Now that helps. Normal for some smoke at idle or low speed. That's the nature of a 2 stroke
Brandon
#11 Post by Brandon » Tue Aug 03, 2010 2:06 pm
Thats good information to know, which is why I love to ask you guys questions on here. I probably would always be turning my motor off once it started smoking forever.
2014 Veranda 22ft
2011 Dodge Ram 1500
I will keep my Guns
JohnO
#12 Post by JohnO » Tue Aug 03, 2010 2:39 pm
I think we need to get this "muff" person in touch with the person who's having a hard time starting his "johnson". Seems like a perfect match to me.
(The two threads are next to each other at this moment)
175 Yamaha VMax
2016 Ford F150
slingshot
#13 Post by slingshot » Tue Aug 03, 2010 4:57 pm
Nice!
Yamaha F150
Snider4
#14 Post by Snider4 » Tue Aug 03, 2010 7:19 pm
Unless we are talking about huge amounts of smoke or the water was not flowing in the muffs it is normal. I have the 06 merc and it smokes too on muffs.
Snider4
Misty Harbor 2080RE
Merc 50
Sprinter Select 26BH
Ohio
