Mounting a Motorguide
rotortrash
#1 Post by rotortrash » Sat Aug 07, 2010 3:51 pm
I just bought a motorguide trolling motor. It has a 60” long shaft and it has 85lbs of thrust, and a wireless remote. I am trying to figure out the best way to mount the Gator mount to the deck of my toon. I don’t have the fishing deck on the front of my toon so I am looking for some ideas. Any help would be appreciated. Thanks!
2002 21' Sun Tracker PB
40Hp Mercury
mike003
Re: Mounting a Motorguide
#2 Post by mike003 » Sat Aug 07, 2010 5:59 pm
Sorry, I don't have a better pic. I have the same motor in 55lb. The mounting plate is just inside the front gate. I open the gate to mount the motor, then close it. I have to open the gate to drop it. If you look closely, you can see the motor between the fishing seats.
2009 Misty Harbor Biscayne Bay 2085FS
Charles Mill Lake, Ohio
oldmn19
#3 Post by oldmn19 » Sat Aug 07, 2010 6:00 pm
Some pictures of the frt and rear deck would help! Have to see what you might have as a mounting spot!
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
dockholiday
#4 Post by dockholiday » Sat Aug 07, 2010 6:07 pm
Welcome Roto
When you say you don't have a fishing deck, do you mean there is no space outside the railing (fence) or do you mean their are just no fishing chairs outside the rail. Here is one that I recently saw posted here......viewtopic.php?f=2&t=5894&p=39279&hilit= ... tor#p39279
Guess you are wanting a permanent mounting as opposed to just something that can be added when you need it.
Sounds like you will have plenty of power with 85lbs of thrust.
#5 Post by HandymanHerb » Sat Aug 07, 2010 6:08 pm
I have 2 fishing seats up front inside of the fence, I mounted mine to one side of the gate and use fasteners so I could remove it quick if I wanted to.
mike003
#6 Post by mike003 » Sat Aug 07, 2010 6:11 pm
I neglected to get a picture and I can't get to the boat for a few days. If you look at this catalog pic of my boat, you'll see the trolling motor plug by the front gate. The mounting plate is installed right next to the plug.
rotortrash
#7 Post by rotortrash » Sun Aug 08, 2010 11:01 am
I should have been more specific on what I am dealing with. There is no deck in front of the fence, I am thinking about making some sort of bracket so the trolling motor is on the out side of the fence. I really don’t want the mount mounted between the seats in the front of the boat.
40Hp Mercury
ezmuny13
#8 Post by ezmuny13 » Sun Aug 08, 2010 11:14 am
here's what i did
rotortrash
#9 Post by rotortrash » Sun Aug 08, 2010 11:44 am
I am thinking about something similar ezmuny, the only problem is the motor guide mount is a lot bigger. http://www.cabelas.com/p-0036678.shtml
40Hp Mercury
ezmuny13
#10 Post by ezmuny13 » Sun Aug 08, 2010 12:19 pm
return it and go with the minn kota............
