bunkboard bracket bumpers
2toytrucks
#1 Post by 2toytrucks » Wed Nov 26, 2008 6:14 am
Our bunkboard support brackets are 2x2 angle iron held to the trailer with u-bolts. The inside of the angle iron was just looking for the right time to rip a hole in a log when trying to load, so after the 1rst close call I needed to do something. I used 1 1/2" pvc pipe and 4- 1 1/2" pvc caps. I measured from the trailer frame to a couple of inches below the belly skin, cut and screwed the pipe to the support brackets and put the caps on just for a clean look. Now if the wind or current makes us miss getting on the trailer we will not damaged a log on the brackets. They work great, have hit them a couple of times and they do not break better yet no damage to the logs. A side benefit is that they stick up out of the water and really help give you a visual of where the bunks are under the water.
Bent support bracket from hit and damage to log after fileing and sanding (so no one gets cut).
Bunkboard support bracket bumpers.
John, Jen, Kim
'07 Parti Kraft Admiral
PKA 220-RE 3 gate
115 Yamaha 4s
Elephant Butte lake
"The coiled snake might seem a strange symbol today. But it was and is effective. No American who ever sees it forgets. "Don't Tread On Me"!
Re: bunkboard bracket bumpers
#2 Post by HandymanHerb » Wed Nov 26, 2008 6:40 am
Good job John, so when are you going to show us how much fun it is to polish toons to a mirror finish
bug73
#3 Post by bug73 » Wed Nov 26, 2008 7:52 pm
Great looking job!
I have to get my toons repolished this spring...no one on my lake has a toon with any sort of polish on it...
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails."
- William Arthur Ward
25 foot Catalina Sailboat
slowdog
#4 Post by slowdog » Sat Nov 29, 2008 1:23 pm
looks very good to me , I am going to ues your idea on my toon too, I love the home growm ideas, most of them work as good as the fractory ones for a lot less $$, thanks for the tip !
WaltF
#5 Post by WaltF » Mon Dec 01, 2008 9:57 am
Actually, a polishing thread would be cool!
Ive wanted to do mine, but listening to the time involved, i havent gotten around to it yet.
Maybe this next spring?
Colorado Springs, CO.
#6 Post by HandymanHerb » Mon Dec 01, 2008 10:15 am
John has a faster way than we did it the first time and after you get them there it's easier to keep clean, but you use sandpaper it the higher grits, depending on how bad you are to start, then go to the highest grit then start polishing, be a whole lot faster than doing it all with the buffing wheel.
2toytrucks
#7 Post by 2toytrucks » Tue Dec 02, 2008 6:25 am
HandymanHerb wrote:John has a faster way than we did it the first time and after you get them there it's easier to keep clean, but you use sandpaper it the higher grits, depending on how bad you are to start, then go to the highest grit then start polishing, be a whole lot faster than doing it all with the buffing wheel.
Ok, just please hold it down a little, my head hurts this am and I feel like I am going to :puke. I will get everything about polishing logs onto a thread along with some pics. Yes, useing 2000-3000 grit wet/dry sandpaper gets the logs ready for final polish much quicker.
John, Jen, Kim
PKA 220-RE 3 gate
115 Yamaha 4s
Elephant Butte lake
#8 Post by lakerunner » Tue Dec 02, 2008 8:08 am
Hate to burst your polished bubble but IMO your nose cone will probably crack. Your gouge looks similar to mine only not as long. The nose cone takes a beating and flexes a lot. I would have them fixed asap.
