My 22ft 2007 South Bay does not have them, turns great, not a chance of getting up on a plane. A while back I had an opportunity to use a 2008 25ft Bennington, these were my thoughts at the time..
Good Day to be on the Lake, bad day on the lake... Page 2
dealership did give us a loaner, a 2008 Bennington 2574RLI
I don't know if it was because of the super strong wind, the extra girth (3ft longer, heavier engine, heavier trailer, etc) or because we ran the AC all day on high, but pulling this thing dropped my gas mileage from 12mpg (when pulling my 2007 South Bay 922CR with the 18yr old 3/4t GMC shown in the pic) to a paultry 7mpg.. I could watch fuel guage move, it made my butt hurt, right around my wallet area....
I had hopes of high speed cruising with this 'toon. Large tubes, lifting strakes inside and out, The Yamaha 150 4 stroke was running a Solex 15x15 aluminum prop. But it did not perform as I had hoped/expected. We heard a lof of what must be cavitation coming from the prop when trying to get 'up to speed', we couldn't give it full throttle from full stop, most of the time when we were up to speed around 2k RPM we still couldn't go full throttle, we had to ease into it, otherwise it sounded like the prop was churning and making froth... I don't know if the following was because of the lifting strakes on the outside of the tubes, or just a normal behaviour of a longer 'toon. But when you would try to corner hard at all, it would lose all forward momentum and cavitate like crazy, no sirens or alerts went off that the motor was overrevving (I had that happen a few times with my SouthBay Optimax when we went over large swells) but if you didn't pull back the throttle it wouldn't bite again. Another thing I thought was weird was that the inner lifting strakes did not extend all the way to the rear of the tubes, but the outer strakes did. Since I have never been on a 'toon with strakes I had expected to 'feel' it lift out of the water when it got up to speed and that just never happened, when I looked over the sides of the 'toon at max throttle (wife was driving) greater than 2/3 (more like 3/4) of the tubes were in the water and I couldn't even see the lifting strakes at the front of the tubes (I assumed that they would be visible if the 'toon was up on them) We didn't have a GPS with us on this trip so I don't know what speed we were actually going, it felt like a good speed... when we were full throttle you could see the top of the cavitation plate just below the water spray indicating good engine depth, but I really felt like the Prop was letting us down. The engine was whisper quiet compared to the Optimax. The 'toon had a lot of nice features like changing room and the extra 'captains' seats in the front.
All that being said, for my next pontoon (or future upgrade to this one) I want a triple toon with lifting strakes on the center tube, both sides and on the insides of the outer tubes and underskinned..
-ron
