GPS on the Toon ??
GPS on the Toon ??
Putting a fishfinder/GPS on the toon. Thinking that silly little white disk has to go up on the Bimini top with the light.
Any better ideas or mounting suggestions for the bimini location ?
Thanks for any input.
Mark
Mark
Re: GPS on the Toon ??
All I have ever seen were on the console
Was it on a post/riser to get it up a bit or flush on the flat in front of the windsheild ?
That sounds better than on the bimini.
I knoew someone had to have a better clue than I did.
Mark
Mark
mine just uses the internal antenna no problems there.
2013 South Bay 442CR STT
150 HP Mercury 4 Stroke
As long as it has a clear view of the sky you're fine. Screw a bracket to the front or back of the bimini and zip-tie the cable down a leg, or if your layout permits, stick it to a forward table or screw a bracket to the front railing. Higher is only suggested to get it clear of obstruction. It needs to "hear" 3 birds to get a triangulated fix.
MrG
2006 32x10 Custom River Cruiser "Regardless"
2007 Evinrude E-Tec 250 2-Stroke
2003 Sea-Doo GTX Limited Supercharged
Ohio River - Evansville, IN
delete==my bad
2009 LOWE SS204 25in logs
90 Merc Optimax
Motorguide W55 Wireless
Underskinning
28 GPS
90 Merc Optimax
Underskinning
28 GPS
Mine is under the bimini top and works just fine.
13 Blazer outboard jet boat
11 12ft Perception Kayak
18 250 6.7 powerstroke
bruuuuce wrote:mine just uses the internal antenna no problems there.
Mine is the same. Built into the unit mounted on the dash and having the bimini up does not interfer with it.
my friends mounts to a flat spot next to unit, Another has built in to unit. Bimini will not inter fear I would think as my sirrius works fine under Bimini
My GPS works fine under my sundeck.
Mine is mounted on a flat surface on the right of my consul, works fine, Bimini is no problem. Just find an out of the way surface and mount it securely so it doesn't vibrate.
22 ft, 90 hp 4s Yamaha
Lorance 332c GPS/Fishfinder
