Tire question
Tire question
ok i have the short fat tires on my trailer and i am going to need to get some now ones, these are dry rotting. any way what do ya think about going with the narrow tires instead of the wide ones? i see a lot of big toons running single axle and skinny tires.. mine is tandum axle... it 24' wit only a few pieces of furniture on it... thanks
1982 Sylvan 24' Toon
50hp Evenruder
my fishin/camping boat
An unarmed man is a subject.
911: Government sponsored Dial-a-Prayer.
When seconds count....Police are minutes away
50hp Evenruder
Re: Tire question
If you go the bigger tires and rims will you have clearances you need?
Re: Tire question
lakerunner wrote:If you go the bigger tires and rims will you have clearances you need?
i didnt want to go bigger i wanted to stay the same hight just go to the skinny tires
50hp Evenruder
50hp Evenruder
Re: Tire question
I have the small fat tires and love'em I am already 12' 4" while on the trailer with the sundeck so they serve me well.
- Alohatoon1
Re: Tire question
There should be a sticker on the trailer that shows the recommended tire size.
Buy what it says to use, you don't want the liability of non-approved tires.
Please visit my website if you get a chance, better yet submit a couple of your favorite photos there!
The Boating Photo of the Day
dockholiday
Re: Tire question
All tires have a load rating stamped on them. Typically the more plies the higher the the load rating. The trailer tires seem to run from 2 ply on the low end to 8to10ply on the high end. I recently bought a spare tire at northern tool and noticed the load rating was several hundred pounds below the ones I have on my trailer now, so I may return it.
http://shop.easternmarine.com/index.cfm ... goryID=157
Re: Tire question
I would stick with the same size and type of tire you have or the trailer recommends. Whatever you do, make sure to buy a trailer tire, or your boat and trailer will be dancing and bouncing all over the highway. I would guess the wider tires would be much more stable for your setup.
"Nauti Weasel"
2005 Beachcomber Islander 26
