Prop toque
Gonefishing
Prop toque
#1 Post by Gonefishing » Tue Jun 28, 2016 12:14 pm
I had to remove my prop. When putting it back on the toque is 40.6. The nut does not line up with the hole for the cotter pin. Should I over toque to match the hole up,or should I under toque to match the hole up?
Bob Jacksonville, Nc
2013 Excursion X23 RFC
2013 115 Yamaha
Pulled with a Ford King Ranch
Re: Prop toque
#2 Post by RcgTexas » Tue Jun 28, 2016 2:17 pm
I personally would not over torque, but then I have never used a torque wrench to put on a prop. I simply tighten till its snug then line up a hole with the nut and put in the pin. You basically just don't want it to have slack to move back and forth. Using that method for the last 55 years I have never lost a prop. It was the way I was taught.
urbnsr
Re: Prop toque
#3 Post by urbnsr » Tue Jun 28, 2016 3:33 pm
My Johnson manual's instructions say to torque and, if necessary, continue to tighten the nut to align the nearest cotter pin hole.
But I just pulled our prop a couple of weeks ago and almost didn't need a wrench to loosen the nut after removing the cotter pin. !
YMMV
Paul
jafo9
Re: Prop toque
#4 Post by jafo9 » Thu Jun 30, 2016 6:12 am
Is that foot or inch pounds? The Honda manual tells me to basically get mine snug. In the past I've been able to take it off with my hand. As far as lining up the hole, I find that usually one hole is clearly closer than the other, so I shoot for that one.
2002 MasterCraft X30
2007 Yamaha FX HO Cruiser
2005 Kawasaki SXR800
2004 Yamaha SuperJet
1989 Kawasaki 650sx
Lewis Smith Lake, Alabama
