Horsepower vs. boat load capacity help
Re: Horsepower vs. boat load capacity help
I have no idea. I guess its the same prop that came with the engine and boat. What would be a good pitch for this boat??
08 Sun Tracker Regency 22
115 HP Mecury Optimax
Tow Vehicle: 2010 V8 Tundra
from what i see only differenc in our toons is i have a third log and mine is a few years older i have a 15p prop and is perfect if you look at the numbers on your prop it will end in a number and a p that is the oitch im geussing it is probly a 13
2004 Sun Tracker Party Barge 22 XP3 Regency
115 mercury
Tri-Toon with Strakes
2004 F-250 Powerstroke
Wabash and White Rivers Mt. Carmel IL
115 mercury
ORAA1997, is your toon an I/O or an Outboard?
You have I/O in your sig, but then list a 115 outboard right below that..
I thought the only I/O engines Sun Tracker put in their toons was the 135 hp mercruiser, which is what i have.
There is no single answer to your question, ORAA1997. The answer is 'it depends'.
You need to find out the best prop for YOUR toon.
You first need to find out what WOT RPM is on your engine. Look it up in your manual.
Thats Wide Open Throttle.
Next look on your toon and see what you have. It will be stamped into the prop somewhere..
Mines a 16x13, 16 being the diameter and 13 being the pitch. (Im about to goto a 16x11)
Then you need to get out on the lake and go full boar(WOT) and see if you are able to reach the WOT RPM that was in the manual.
If not, then you need to try another prop, one with less pitch.
Every 1 degrees less in pitch = a gain of about 200 rpm.
Once you have this set right, it will be as fast as your toon will go.
Dont expect to beat a 150 hp bass boat though... heh
So, the prop that works for YOU will be the one that allows the engine to reach WOT.
Colorado Springs, CO.
I was curious about the i/o or outboard myself. If it has a 115 mercury then its not an i/o
115 mercury
115 mercury
I thought the 1st. number was the dia. and the 2nd. the pitch. I have a 13 1/4 x 17, I was told the 17 was my pitch.WaltF wrote:ORAA1997, is your toon an I/O or an Outboard?
Dont expect to beat a 150 hp bass boat though... heh![]()
"Nauti Weasel"
2005 Beachcomber Islander 26
gxp that is the diam and pitch mercury did not label mine like that just a part number and pitch
115 mercury
115 mercury
Thats a good question GXPWeasel.
Ive seen them labeled both ways.. not sure why, but ill bet someone in here knows...
My Mercury Black max/Quick silver prop is labeled dia x pitch.
Here is the 16x11 prop i just recently bought from Dan's Discount props:
Mercury - Mariner Outboards. Mercruiser Alpha I,II & Bravo I Sterndrives. 135 HP & Higher Aluminum Propellers
DIAMETER PITCH -> 16x11
PART NUMBER -> QA2000X(48-78112A45)
PRICE -> $96.95
http://www.dansdiscountprops.com/BuyNow ... icksilverA
PRICE -> $96.95
How fast is crawling in the water that you refer to?
OK I fixed the signature. I will have to check out the prop to see the pitch. Thanks for all the great info. One last thing. Would it be a good idea to test out the props on an empty boat or with a normal load?
dockholiday
I usually check it out on an empty boat, but think the correct way is with the load you will normally be carrying.
My normal load is 12 people, and im never reaching WOT then.. LOL!!
Man I am getting confused all you sum bitches have the same boat in your avatar...
At least I got their daddy in mine.
pepper1126
I have a Yamaha 115 and I have only taken it out once and with very rough water and the throttle not even pinned, I had that baby up to 29mph. I think its all about the conditions.
Pepper1126
2007 G3 Suncatcher 25LX
Yamaha 115 2-Stroke
Lake Lanier, GA
Yamaha 115 2-Stroke
Lake Lanier, GA
Man, I had a reality check this past weekend! I had never been out with the toon heavily loaded. This time I had 1350+ pounds on board. Never got up on the strakes and max speed with best trim and distribution was around 20 MPH GPS, lower in the rough water. I would hate to think what the original 60 HP would have been limited to in this situation.
BUY ALL THE HORSEPOWER YOU CAN UP TO THE LIMIT OF THE BOAT... YOU WILL ONLY REGRET NOT HAVING IT WHEN YOU NEED IT!
It was a great weekend and we are going back this weekend. Hope all of you can get on the water soon.
2007 GMC Sierra
2007 GMC Sierra
