Person/Weight Regulations??????
I have just purchased a 1985 24' Lowe Sunbird w/a 1977 85HP Evinrude. The boat does not have the regulation sticker on it. (weight/# of people) I need to find out what the weight/# of persons is & also where I can get a sticker. Thanks!!
- BOAT.jpg (129.59 KiB) Viewed 5524 times
OBG Newalla, OK.
1985 24' Lowe Sunbird/1977 85H.P. Evinrude
2006 Ford F-150, 2WD, V8
Single axle trailer
Single axle trailer
Re: Person/Weight Regulations??????
Mine is on the back of the panel you open under the steering console... Have you looked there?
No I haven't. Will do that. Thanks!
OBG Newalla, OK.
Single axle trailer
Single axle trailer
Nope...not there. Any other suggestions? It is an old boat, I wonder if the previous owners took it off. I just really need to know how many people or weight I can get on the boat. There is 5 of us, then I have a sister with a husband & 2 kids. (9 people total on a regular basis)
OBG Newalla, OK.
Single axle trailer
Single axle trailer
If you take too many and it starts to sink, can't you just start throwing the least important people overboard?
I think that's why they make you carry one life jacket for every person on your boat.
Stephen & Gina
"It's Aboat Time"
2007 Godfrey Sweetwater Tuscany Series, 21'
2002 GMC Sierra 1500
Lake Arrowhead, TX
"Work is hard. Distractions are plentiful. And time is short."
-Adam Hochschild
"It's Aboat Time"
Lake Arrowhead, TX
-Adam Hochschild
LOL...I may be doing that even if it doesn't start to sink!!!
OBG Newalla, OK.
Single axle trailer
Single axle trailer
Just call up a bunch of people, and ask them to come join you on your new boat ( Usually very easy to get people to come with you). Then, start letting people board the boat. Made sure to try and spread everyone out evenly, and once is starts to get water on the deck, you know to subtract 1 from the number of people on board, and you have the number of people you boat can hold. To transfer into weight, simply weigh each person you had on the boat.
Ok, seriously, here is what you can do.
#1, look up your boat on the internet, and see if you can find a local dealer. If so, call them up, and see if they have this info. on your boat.
#2, Find a similar boat in both lenght, # of toons, Dia. of toons, construction ( alluminum deck, wood deck) and see if someone has a similar boat, and they can tell you their weight limit. I have a 26' toon, with 25" logs,(2) and aluminum decking. My boat says 14 people, and I'm not positive on the lbs. (I think they usually figure about 125lbs. / person though). Also, don't forget that weight includes Coolers, life vest, and any other cargo on board. Hopefully this can get you close.
#3 Visit your nearest Wildlife & Parks, or thier website, and see if you can get the boat inspected, or if they can help you. I know if you want to change the horsepower of motor your boat can safely hold, you can have them inspect, and change, so maybe they can help on this as well. After all, they are located on teh same sticker ( at least mine is).
Oh, check this out too. Very similar boat, ask him what his weight limit / capacity is, and there you have it.
http://www.marine-trader-usa.com/boat/2 ... ith_85_hp/
"Nauti Weasel"
2005 Beachcomber Islander 26
LOL...Thanks GFPWeasel!! I sent him a message asking him. We shall see if he replies. Thanks for the laugh & the info!!!
OBG Newalla, OK.
Single axle trailer
Single axle trailer
That toon likely has a 12 person rating, 2400 lb including motor
You may also try to email or call Lowe, they may be able to help.
Sheridan, Indiana
Sheridan, Indiana
check this out should get what ya need
http://www.fish.state.pa.us/anglerboate ... ppmath.pdf
or
http://www.ehow.com/how_4722317_determi ... -boat.html
or
2004 Sun Tracker Party Barge 22 XP3 Regency
115 mercury
Tri-Toon with Strakes
2004 F-250 Powerstroke
Wabash and White Rivers Mt. Carmel IL
115 mercury
That website was perfect!!! Thank You!!
OBG Newalla, OK.
Single axle trailer
Single axle trailer
- FloterBoter
your state laws probably require the placard attached to your boat.
