water in toon log
phat06
water in toon log
#1 Post by phat06 » Mon Jun 28, 2010 11:25 am
Hello fellow toon owners. I recently purchased a used 2001 22 foot Sun Tracker regency party barge. the original owner treated it very poorly. Ive been rebuilding for about 4 months now took it out last weekend and it leans to the left with just the driver in it. I can hear water in the logs so i drilled holes in the rear of both logs welded in fittings for pipe plugs,quite a bit of water came out of the left log and none came out of the right. I can move the toon around while its still on the trailer and hear water sloshing around in the front. My question is do the logs have a seperator in them? I made sure i tilted the toon back far enough to get the water to flow to the back. how do i get the water out from the front. There are plastic plugs in the top, but there in the middle of the logs.
newlights
Re: water in toon log
#2 Post by newlights » Mon Jun 28, 2010 11:31 am
I dont know why they would have a seperator in them but sounds like yours probably does. Im not the best guy to ask this question though.
__________________________
1989 Lowe 24ft
1991 Yamaha 85 HP
dockholiday
#3 Post by dockholiday » Mon Jun 28, 2010 11:37 am
You probably have separate chambers if there are top plugs on each section. Just use a siphon hose.
toondog
#4 Post by toondog » Mon Jun 28, 2010 12:27 pm
Like doc said, if you have more than one nylon plug on top of the logs, you most likely have separate sealed chambers. I would open each chamber and listen for s swoosh of air coming out. If you hear that swoosh, that chamber is OK. The ones that don't are the ones with the water. To make sure, drop a fishing weight on a string down each chamber until you hear it hit the bottom. Pull up and check for moister.
To get the water out use some kind of siphon hose. I used a boat fuel hose in reverse to get the water in my tubes out.
13 Blazer outboard jet boat
11 12ft Perception Kayak
18 250 6.7 powerstroke
toondog
#5 Post by toondog » Mon Jun 28, 2010 12:36 pm
newlights wrote:I dont know why they would have a seperator in them but sounds like yours probably does. Im not the best guy to ask this question though.
That's why forums are so great. The more you read the more you learn. Helps eliminate the burn and learn method.
The majority of logs out there fall into three category's. U shaped filled with foam, sealed chambered and baffled chambers. The last two types have separators that keep the log from completely filling with water in case you rip a hole in one chamber. That's what makes a pontoon almost unsinkable.
newlights
#6 Post by newlights » Mon Jun 28, 2010 1:46 pm
That makes sense kind of the titanic method but a better approach. I havent been ehre long but I love this forum! I wish my pontoon would get done at the mechanic I want to use it for the first time!!! BTW the pontoon on my avatar is not my toon lol its one i snagged pictures from a craigslist ad for sale at 400 bucks lol. a little home built.
1989 Lowe 24ft
1991 Yamaha 85 HP
pontuna
#7 Post by pontuna » Mon Jun 28, 2010 4:37 pm
I use a 12 volt pump from harbor freight to pump the logs out. I was wonder what can be used to seal the logs, would marine tech work or is there a good caulk. I know welding is the best but it can be expensive.
Bob
OlJim
#8 Post by OlJim » Mon Jun 28, 2010 5:06 pm
If you have access to a Helli arc machine and apparently you do as you welded in drain plugs, drill a small hole in tube and drain water. I would then use air hose to apply a small amount of air pressure and soapy water to try and find where the water got in and then weld up both holes.
I have a friend that has one of those two man bass boats that gets water inside between the hulls. He has drilled holes all over that thing and later plugged them with screws. Since there is little pressure it doesn't take much to seal a small hole.
2007 Suntracker PB 22
Regency Edition
MororGuide TM 55lb. Thrust
With Wireless Remote
Humminbird 737 Locator With GPS
90 HP Mercury
#9 Post by lakerunner » Mon Jun 28, 2010 5:16 pm
You should have 3 chambers. 2 round and nosecone
tuned
#10 Post by tuned » Tue Jun 29, 2010 8:33 pm
Here is a cutaway of my baffled Premiere log. Note the vent tube on top rather than a sealed bung. It will allow water to flow from front chamber to rear (I proved it :lol3 )
toondog
#11 Post by toondog » Wed Jun 30, 2010 1:29 pm
Excellent picture of a baffled chamber tube. :thumbsup And what is a bung? Besides what I'm thinking.
tuned
#12 Post by tuned » Wed Jun 30, 2010 5:47 pm
toondog wrote:And what is a bung? Besides what I'm thinking.
I think you already answered your own question.
toondog wrote: if you have more than one nylon plug on top of the logs, you most likely have separate sealed chambers.
I think the word came from Ye Olde wine and beer barrels which were sealed with a cork hammered into the pour hole, aka known as a bung and a bunghole.
Of course, B&B would probably make reference as a cork hammered into my POOR hole. :smoke
dockholiday
#13 Post by dockholiday » Wed Jun 30, 2010 7:28 pm
FloterBoter
#14 Post by FloterBoter » Wed Jun 30, 2010 8:28 pm
yeah, i believe the "separate" chambers have an air passage between them. so one "whoosh" when you open a top plug, but you need to check the bottom of each chamber for water.
toondog
#15 Post by toondog » Thu Jul 01, 2010 3:07 pm
FloterBoter wrote:yeah, i believe the "separate" chambers have an air passage between them. so one "whoosh" when you open a top plug, but you need to check the bottom of each chamber for water.
Multi bungs + sealed chambers = multi swooshes
tuned wrote:I think the word came from Ye Olde wine and beer barrels which were sealed with a cork hammered into the pour hole, aka known as a bung and a bunghole.
Stop using those big words I don't understand. :?
Thanks doc. :thumbsup
bung1    /bʌŋ/ Show Spelled[buhng] Show IPA
–noun
1. a stopper for the opening of a cask.
2. a bunghole.
–verb (used with object)
3. to close with or as if with a bung; cork; plug (often fol. by up ).
