Lower unit off time to order the new one
GregF
Re: Lower unit off time to order the new one
#31 Post by GregF » Thu May 12, 2011 3:33 pm
Are you sure you didn't drop the key that drives the impeller? That will bite you too.
I have had one defective impeller so far, spun hub, and it showed up right away with your symptom.
1974 Harris
70 HP 4 stroke EFI Yamaha
#32 Post by curtiscapk » Thu May 12, 2011 4:58 pm
Coupler is there. I read to vaseline it though, I think I can figure out with above.
lakerunner696
#33 Post by lakerunner696 » Thu May 12, 2011 5:07 pm
For some reason some mercs when you change impellers and hook muffs it won't pee. We did a friends Merc 135 and had that issue. I don't know how many times we dropped the lower unit and reinstalled it still no pee. A neighbor had the same thing happen and dealer said put it in the water and it should pee. Sure enough it had a good solid stream and now will on muffs. I have no idea why but it worked.
2008 F150 Lariat Super Crew
Haul Rite trailer
GregF
#34 Post by GregF » Thu May 12, 2011 7:29 pm
I usually put mine in a trash can to run it if I am not running on the flush port. Just don't put it in gear ;)
1974 Harris
#35 Post by Bamaman » Thu May 12, 2011 8:36 pm
If funds is a major issue, an alternative would be to find a good quality boat salvage operation to look for a used lower unit. LanierMarine.com in North Atlanta/Buford, GA is a source with hundreds of used boats in stock in dis-assembly. BoatTrader.com and/or EBayMotors.com can point you to other sources of lower units.
On my lake, lower units are often stolen in the middle of the night from boathouses--a 5 minute job. Good lower units are often fenced to Florida salvage yards. Insurance companies pay out the nose for new replacement lower units around here.
GXPWeasel
#36 Post by GXPWeasel » Fri May 13, 2011 11:36 am
Bamaman wrote:If funds is a major issue, an alternative would be to find a good quality boat salvage operation to look for a used lower unit.
^^ He just did that.
"Nauti Weasel"
2005 Beachcomber Islander 26
Re: Lower unit off time to order the new one (update)
#37 Post by curtiscapk » Fri Jun 03, 2011 7:04 am
Well,
I got the Lower to pee! :nana I had missed a seal on the water tube. :paranoid But bad clanking now coming from top end. :x I don't know what it is, it was altogether a shitty weekend.... I couldn't find the compression tester so I just gave up until my bro came up with it. He swore it was by his toon, but I couldn't find it and I wasn't wasting any troubleshooting time without knowing if something major had happened. I will let you know in a couple weeks when I go back down. The lower did shift fantastic so that was a good buy for 600. I may take her in if compression is good. That way they can't give me the "oh man your motor is shot" line. :roll:
#38 Post by curtiscapk » Mon Jun 13, 2011 11:15 am
Well here are the pics of my compression and a video of it running the knock sounds a lot worse in person.
Remember this is a 17 year old motor still with 125 lbs. Damn I wish they all had it.
I stopped at PJ's Marine outside of Clinton and he quoted me 800 at the worst if it was the connecting rod and not just rings. So for 600 - 800 hundred back in business, with vacation coming up it may be sittin for awhile.
I think a damn good price after seeing Rolands post. It just sucks that the lower and upper go out together.
Someone help me on the youtube link (my first one) after they changed awhile back.
[youtube]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/xXVFcEyojyI?hl ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/xXVFcEyojyI?hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube]
Number four
number three
Number two
number one dry
Number one wet.
Bamby
#39 Post by Bamby » Mon Jun 13, 2011 11:57 am
Here you go:
Kind of reminds me of a old time thrashing machine....
#40 Post by curtiscapk » Mon Jun 13, 2011 12:03 pm
Thanks Bamby. Yeah the piston is slapping pretty good. She gonna sit for awhile. :( :( :cry:
